Low volume output from subwoofer
  • Emilf
    • Mar 2014
    • 12
    • Iceland
    I've got a KLH ASW12-200b subwoofer that turns on and outputs sound but at a really low volume. I have to max my bass, treble and subwoofer levels in my AV receiver as well as putting the gain to max to get any useful sound out of it.
    I have checked the RCA plugs and they seem fine. But I noticed that some capacitors on the control and power boards seem to be leaking? I'm a newbie when it comes to these types of things so I would appreciate some input from you guys on the best course of action to fix it up.
    Below I have attached pictures of the caps that I believe are damaged.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Low volume output from subwoofer
    That stuff around the caps is glue or sometimes silicon used to hold the caps in place during manufacture. I would troubleshoot in this order:
    1. Clean the boards free of dust and other debris that may have accumulated.
    2. Look for loose connections and cold solder joints on the board traces.
    3. Look for resistors that may have burn spots, especially the 1W-3W sizes.
    4. Look for bac caps. Do ESR test.
    5. Power up and connect signal.
    6. Check Output IC/Trasistors for overheeating.
    7. Verify gain control is working.
    8. Check the speaker for increased impedence or loose 'pigtail' wires to the Voice coils.
    Hope this helps.
    AFA
      Can you take the pictures that will show all the board, also the pictures of the panel that shows the inputs and the controls?
      • Emilf
        • Mar 2014
        • 12
        • Iceland
        Will do that as soon as I get home. Thanks for the input guys.
        • Emilf
          • Mar 2014
          • 12
          • Iceland
          Also when I turn it on it flutters for a little bit before settling down.
            One thing I see are those bad brown glue that will eat away the wires and copper traces, they also become conductive. They should be removed.
            You can also see here what bad glue can do to the boards.
            https://www.badcaps.net/forum/showthread.php?t=34692
            • Emilf
              • Mar 2014
              • 12
              • Iceland
              Under the bigger capacitors is that also glue that should be removed? Also whats the best way to remove the glue?
                Glue on the big caps, by the grey ribbon cable, etc. I use Alcohol to soften them first then scrape them off.
                • Emilf
                  • Mar 2014
                  • 12
                  • Iceland
                  Here are some more pictures. I noticed on the back of the PCB that the soldering seems to be sloppy on some points. Some resistors or capacitors seem to be solder together on the + and - wires. It's noticeable in the upper right corner on the first 2 pictures, is this something I need to worry about?
                  I also scrapped away most of the glue and it changed nothing.
                  I also noticed that the woofer cone seems to flutter a little when I move the Gain dial.
                    It does not look like it will be easy to trace out the connection, I usually trace the circuit back from the power amp input circuit back to the input front end.
                    • karthur
                      Vizio D65x-G4 Volume changes on its own
                      by karthur
                      On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                      It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                      06-05-2025, 08:13 AM
                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                      by sam_sam_sam
                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                      I bought this from an eBay seller but unfortunately they only had one
                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                      I bought three of from them to also make battery packs with this output power limit in mind
                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                      04-23-2025, 05:50 AM
                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                      by momaka
                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                      09-19-2021, 08:44 PM
                    • FrancescoV
                      Onkyo HT-R390 no sound output, video output ok
                      by FrancescoV
                      Good morning everyone,
                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                      The firmware reported is the following:
                      M:1.00/11107BLP
                      D:?.??/????????
                      O:1.00/11107AL
                      The DSP firmware given the question marks seems corrupt.
                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                      05-11-2025, 02:59 AM
                    • CoppellTVRepair
                      Troubleshooting PFC with SPC1012T not raising output
                      by CoppellTVRepair
                      It has been a long while since I posted here to ask anything....hope you can help.
                      I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                      I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                      03-09-2025, 10:38 PM
