SONY MDR-RF820R capacitor replacement?
  • UserXP
    • Apr 2012
    • 443
    • Serbia
    Hi, all. I would like to ask for your opinion, guys. It is about capacitor replacement, but please read the description:
    I have these wireless SONY headphones MDR-RF820R, which work OK most of the times. However, the transmitter (base) would sometimes behave as if it had a drop of power. This happens very shortly after it is put in use (powered on), and would repeat this loss of power on its own and in random cycles. The "Power ON" LED would blink for a second, and the whole base would shut down for that bit of a second at the same time, then immediately resume back to normal - as if somebody quickly unplugged and then replugged the power cord. While this power outage occurs, because of an obvious signal loss, the headphones produce a very loud and unpleasant scratching sound during that bit of a second. So if I am in the middle of some listening to the music, this literally hurts my ears, especially if the volume is higher. As soon as the base resumes its operation, the headphones work normal as they are receiving the signal again.
    Because it is the base that showed this weird behavior, I opened it up. Upon opening the base, all the capacitors inside are Rubycon YX series and they are mostly 50V 47uF or 10uF, except for the three larger capacitors which are 16V, 220uF and they are all Sam Young SHL series. None of the capacitors looked bulgy or somehow suspicious.
    Now, while testing, I put three Rubycons on the soldering places of these three Sam Youngs (one for each of them) just to see if there would be a difference. I chose them because following the paths on the board all of them were connected to the main power and negative lead, so I though they are probably there to provide stable current or something. The Rubycons I've connected were 16V, 470uF, YXG series (I had those at my disposal). The problem immidiately disappeared! Now, can you tell me, can I remove these Sam Youngs and replace them with these Rubycons which are twice as much the capacitance? Is this difference in capacitance safe?
    The base is powered by an AC-DC adaptor which outputs a 9V DC.
    Thanks in advance for your suggestions, I would really like to fix this if possible. I stopped using them because of the constant anticipation of the unpleasant sound while listening to something.
    Re: SONY MDR-RF820R capacitor replacement?
    More capacitance the more inrush current when the unit is first power up, so it depends on how much the inrush current the rectifier diodes and the transformer can handle, once it is on it is OK, only when you first apply the power, you may be OK.
    • UserXP
      • Apr 2012
      • 443
      • Serbia
      Thanks for the quick reply, Budm. I have no idea what those are . If you want me to read some markings on the surrounding components, feel free to ask. I can also try to make some clear pictures if that'll help, just tell what specifically to take picture of.
      The base is always plugged in, it powers on automatically as soon as it senses the audio signal from the equipment (in this case, the computer). If there is no audio signal for about 4 minutes, it shuts itself down and goes to "stand-by" mode, as the 9V DC plug is always plugged in and providing power (it is a separate AC-DC adaptor, like for cordless phones).
      So, the general idea is that these Rubycons should do the job? They won't get damaged, or something else damaged, because of this difference in capacitance?
      I tried comparing the data sheet, but with Sam Youngs, I couldn't get a hand of it and the datasheet was not very clear to me. I do not know the electronics and symbols, but I just wanted to compare the identical units and their values. But while Rubycon's datasheet has actual and clear values, Sam Young has them "in range, from-to". So I didn't quite understand...
        The Rubycon is much better, high ripple current and low ESR, 105C rating, long life:
        https://cdn.badcaps-static.com/pdfs/...5648e9175f.pdf
        Samyoung is the general purpose 85c rating cap.
        https://cdn.badcaps-static.com/pdfs/...d928d89b06.pdf
        Three 220uF x 3 = 660uF (if all those 3 are connected in parallel, need pictures to verify), then 470uF x 2 = 940uF so you only need 2 Rubycon caps.
        Rubycon is the better cap.
        • UserXP
          • Apr 2012
          • 443
          • Serbia
          Yes, I know they are better. I bought these a while a go for some other repair, and still have some left. So I thought I could put them in as a replacement, also all the caps on the board would then be from the same maker.
          OK, I will try and see how it works. If the annoying and ear-tearing sounds stop, it will deffinitely be a plus.
            master hoarder
            • May 2008
            • 12175
            The Rubycon YXG you used should be okay, even though they are twice the capacitance. It takes A LOT of extra bulk capacitance to kill the rectifiers in those AC-DC adapters (both switching and linear).
            Now my only concern is where did you buy those Rubycon YXG capacitors? eBay? If yes, then please do post some pictures because the caps on eBay are often counterfeit.
            • UserXP
              • Apr 2012
              • 443
              • Serbia
              Guys, I am so sorry, there was a typematic mistake made by me. The series is YXF, not YXG.
              Momaka, thanks for your input. There is a very big difference in how these headphones work now. The horrible "power loss" noise never reoccurred after mounting these Rubycon capacitors, obviously they do their job well. We bought these caps from this guy on eBay (this is the actual listing):
              http://www.ebay.com/itm/10-Rubycon-Y...-/290751508758
              There were 10 pieces in the package, they look genuine. Do you think they are OK? I will post some pictures of the actual capacitors if you'd like.
                master hoarder
                • May 2008
                • 12175
                Those are genuine, so you're good .
                Seller egekecu (also known as PCMCS) is one of the very, very few sellers on eBay that sells genuine capacitors.
                • dbuergi
                  Sony WH 1000XM4 Headphones always on because of corosion?
                  by dbuergi
                  i got these headphones which were not charging or powering on. I found some corosion around the charging port and power board. After cleaning the headphones took a charge but directly powered on.
                  The power button ist without any reaction. I suggest that there ist still some gunk under the button and i get an always power on. Do you have any suggestions what to do? Is it possible to desolder the button for a cleaning?
                  I could replace the board for 25 euros but maybe there is another way?
                  11-04-2024, 09:29 AM
                • Califauna
                  Connecting charger cable causes Sony WH-10000MX2 bluetooth headphones to stop working
                  by Califauna
                  I have a pair of WH-10000MX2 bluetooth headphones with a strange problem. Connecting the charging cable causes the headphones to no longer turn on when pressing the power button.
                  I thought I had 'fixed' this when I took them apart and disconnected the battery for 15 minutes and found as soon as you disconnect the battery they can be powered on and off as normal using the power button. But then the moment you connect a charging or data cable to a charger or laptop USB port, the power button stops working and the can't be turned on again. No response.
                  The...
                  02-28-2024, 06:14 AM
                • timonix20
                  Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
                  by timonix20
                  hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
                  the TV starts, LG logo, then nothing (rear backlight)
                  no reaction to rear command or infrared
                  the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
                  I have a chance with a usb procedure or other if you have .bin
                  if any people have this main board
                  thank you...
                  04-23-2024, 01:52 PM
                • FZG
                  Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
                  by FZG
                  Hello there, helpful forum people!
                  I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
                  On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
                  The original part...
                  05-10-2023, 11:54 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
