What about this BT EHSB14CDB IC?
  • Albi R
    • Sep 2023
    • 5
    • Albania
    Hi Guys, first time for me to ask here.
    I have a cheap Turn Table with Bluetooth incorporated. The BT ic (EHSB14CDB) has no output, i think the ic is not working but I can't find any info about it.
    Do you have any idea about this IC?
    Thanks in advance.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8332
    If the Bluetooth connects but there isn’t any audio, I think your problem is somewhere else.
    • Albi R
      • Sep 2023
      • 5
      • Albania
      Thank You CapLeaker for reponding.
      There is 3.6v-3.7v on the Pin10 feeding the ic but no Bluetooth detect to my phone. Pin17 and 18 are connected to Green and Blue Led through resistors but there is no light at all.
      May be a on/off pin is not activated, this is why i'm trying to find any info for the ic.
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        It's one of those custom OEM ICs made in China that has no published datasheet.
        I'd just remove the chip and install a separate audio bluetooth 5.0 module, run jumper wires from the module to these pads: input, output, ground, VCC supply and status LED indicators.
        Who cares if it's gonna look janky as long as it works.
        • Albi R
          • Sep 2023
          • 5
          • Albania
          Thank You прямо​ for the idea.
          This one here, AB Bluetooth device has similar pin-out with mine:
          .http://www.ch-chip.com/Data/ch-chip/...0DataSheet.pdf
          What Voltages I have in my Ic are:
          Pin2 DAC power = 0V
          Pin9 VDDIO power output = 500mV
          Pin10 VBAT power input = 3.7V
          Pin13 Power key input = 3V
          Other connections:
          Pin17 and 18 = Blue and Green LED
          Pin5 and Pin6 audio input.
          Pin23 DacR = Audio out
          Pin24 DacL = Audio out
          I suspect the IC is faulty. What do you think Guys?
          Thanks.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            The IC source is Shenzhen Bluetrum Technology Co., Ltd.
            https://www.bluetrum.com/product/list-speaker.html
            ​Now you need a Chinese translator ..
