What is this component marked G75LL on it? (U15) from a KW-M56BT audio system
This topic has been answered.
  • bogosort
    • May 2022
    • 78
    This audio system does not turn on and I managed to see that this component heats up when powered.
    Anyone knows what this component is?
  • Answer selected by bogosort at 12-20-2023, 06:55 PM.
    redwire
    • 3910
    I show SMD marking G75xx as SGM2203-3.3 It is an LDO 3.3V 150mA in SOT-89 package, pinout GND, IN, OUT.
    • redwire
      • 3910
      • bogosort
        • May 2022
        • 78
        Thank you! Is there a way to find this kind of information or is this your knowledge?
        • redwire
          • 3910
          I Startpage searched but with just the main numbers like "G75" - not the manufacturing plant info. An entire marking code is rarely listed, but the root part is.
          The IC does not have much heatsinking so it will easily run hot. If it has 3.3V output then I would check other power supply voltages.
          • Mark R
            • Oct 2023
            • 71
            I went to Mouser out of Texas.. They are pretty big.. I have an account there.. Looks like Rewire did all the work I plugged in his numbers and description... https://www.mouser.com/c/?q=LDO%203....%20in%20SOT-89
            This is what I plugged in.. LDO 3.3V 150mA in SOT-89
            Redwire to the rescue 👍
            You can buy one piece of anything there, Give them a call...Rea Nice Peep's.
            sigpichttps://www.badcaps.net/forum/image....ine=1697924519
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
            • i_am_patch
              Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
              by i_am_patch
              Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
              04-30-2024, 08:20 PM
            • MOSSEP
              Monitor Audio RSW12 - Green light but no audio
              by MOSSEP
              Hi
              Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
              Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
              The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
              I have already tried replacing all of the...
              01-26-2025, 08:18 AM
            • grimacelord
              MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
              by grimacelord
              I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
              12-11-2023, 11:13 AM
            • chbalnuweit
              HP 840 G5 Shorted Audio IC
              by chbalnuweit
              so I made a stupid mistake and dropped a screw onto the motherboard while assembling it.
              The screw fell right onto the battery connector area and unforunately managed to short one of the supply voltage lines of the Audio IC (Conexanct CX 7750) without me noticing at first.
              After the assembly and booting Windows I noticed that there was no sound and no Audio IC detected in device manager...
              I got the motherboard out again and found the Audio IC with a crater in it...
              Luckily I got a donor board with the same model motherboard....
              11-19-2023, 12:12 PM
