What is this component marked G75LL on it? (U15) from a KW-M56BT audio system
This topic has been answered.
  • bogosort
    • May 2022
    • 78
    This audio system does not turn on and I managed to see that this component heats up when powered.
    Anyone knows what this component is?
  • Answer selected by bogosort at 12-20-2023, 06:55 PM.
    redwire
    • Dec 2010
    • 3912
    I show SMD marking G75xx as SGM2203-3.3 It is an LDO 3.3V 150mA in SOT-89 package, pinout GND, IN, OUT.
    • redwire
      • Dec 2010
      • 3912
      • bogosort
        • May 2022
        • 78
        Thank you! Is there a way to find this kind of information or is this your knowledge?
        • redwire
          • Dec 2010
          • 3912
          I Startpage searched but with just the main numbers like "G75" - not the manufacturing plant info. An entire marking code is rarely listed, but the root part is.
          The IC does not have much heatsinking so it will easily run hot. If it has 3.3V output then I would check other power supply voltages.
          • Mark R
            • Oct 2023
            • 92
            I went to Mouser out of Texas.. They are pretty big.. I have an account there.. Looks like Rewire did all the work I plugged in his numbers and description... https://www.mouser.com/c/?q=LDO%203....%20in%20SOT-89
            This is what I plugged in.. LDO 3.3V 150mA in SOT-89
            Redwire to the rescue 👍
            You can buy one piece of anything there, Give them a call...Rea Nice Peep's.
            sigpichttps://www.badcaps.net/forum/image....ine=1697924519
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
            • kotel studios
              Lantec PULSE 386 subwoofer - no audio output
              by kotel studios
              Hi
              I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
              After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
              The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
              11-29-2025, 04:15 AM
            • i_am_patch
              Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
              by i_am_patch
              Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
              04-30-2024, 08:20 PM
            • silver60618
              Macbook M3 A2991 Speaker Audio Amplifier IC
              by silver60618
              Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
              I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
              09-26-2025, 12:25 PM
            • MOSSEP
              Monitor Audio RSW12 - Green light but no audio
              by MOSSEP
              Hi
              Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
              Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
              The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
              I have already tried replacing all of the...
              01-26-2025, 08:18 AM
