I have a pioneer Sx-3400 and 2 10" sub's. I put the subwoofer out on my yahmah to right aux on the pioneer and hooked up the 2 sub's to right out on the pioneer. It worked fine for 10 minutes on vol level 8 of 10 then a fuse popped on the pioneer. Can I fix this problem (fixing the amp is not the problem) or do I have to fork over $180 for a subwoofer amp.
old stereo recover as subwoofer amp
I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Service Menu/Factory Reset Codes for TVs
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: old stereo recover as subwoofer amp
Check impedance of the speakers and also check the amp's manual to see what is the minimum that it will accept.
Some older amps are strictly rated for 6 or 8 Ohms per channel minimum. According to HiFiEngine, this amp is rated for 15W into 8 Ohms. If your 10" subs are rated for 4 Ohms impedance each and you had them hooked in parallel, the total impedance was 2 Ohms. Most older are not rated for an impedance that low. If you had them hooked in series, you might have not had a problem. But who knows. You may have just been pushing the amp too far, as well. Did you hear any clipping from the 10" subs while you were running this setup?Last edited by momaka; 12-28-2013, 10:10 PM. -
no clipping, ill try 1 speaker per channel. If it doesnt work ill try and find another amp from my local recycle center.Check impedance of the speakers and also check the amp's manual to see what is the minimum that it will accept.
Some older amps are strictly rated for 6 or 8 Ohms per channel minimum. According to HiFiEngine, this amp is rated for 15W into 8 Ohms. If your 10" subs are rated for 4 Ohms impedance each and you had them hooked in parallel, the total impedance was 2 Ohms. Most older are not rated for an impedance that low. If you had them hooked in series, you might have not had a problem. But who knows. You may have just been pushing the amp too far, as well. Did you hear any clipping from the 10" subs while you were running this setup?I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Again, you have to check the impedance rating of your subwoofers. Otherwise you'll simply keep blowing amplifiers (and possibly your subwoofers too) if they made to drive those subwoofers. Most speakers have a label on them that states their impedance. Gotta make sure the woofer impedance is the same or higher than the minimum supported by the amplifier. If the subwoofers are 4 Ohms each, go with a car amplifier. Even a cheap one will do okay. You don't really have to spend $180 on a subwoofer amp.Last edited by momaka; 12-29-2013, 04:48 PM.Comment
8 ohms, should i try putting them in series?I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
One per channel will work if they're 8 ohms. But that amp is pretty weak for subwoofers. Putting them in series will definitely work, but they'll be even quieter that way, so it's pretty pointless.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I can't believe I never thout about one per channel.I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
by kodiacI have rx-750 pioneer stereo and the stored radio stations in the memory does not stay in the memory very long.
Does anyone know where the memory is located in this stereo and how it is powered up?
It does not have a battery backup.
Does the memory use a capacitor for its power supply?
thank you -
by rustinjustI've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
Is there a way of... -
by rustinjustI’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
Is there...-
Hi
I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...-
11-29-2025, 04:15 AM -
by LEECH666Good day ladies and gentleman!
I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
I think the PSU buzzing comes from one of the coils near the bridge rectifier but... - Loading...
