Pioneer VSX-1022-K won't turn on
  • tibimakai
    • Jan 2012
    • 3680
    Re: Pioneer VSX-1022-K won't turn on
    At the relay's coils I measure 10.5V. This voltage shouldn't turn on the relay?
    There is also a zener diode D303 which looks like a 7.5V zener diode. There it shouldn't be a 7.5V at the relay?
    On one side of the R319(transistor side) I'm measuring 0.73V and at the other side 3.3V while I'm resetting the receiver.
    • rievax_60
      • May 2012
      • 897
      • australia
      #62
      The 10.5v will only turn on the relay if the bottom end of the coil is grounded by the transistor. The 0.73v at the Base indicates that the transistor is being turned on.
      Have you checked under the PCB for problems?
      The zenner is there to limit the voltage across the coil to about 7.5v.
      • tibimakai
        • Jan 2012
        • 3680
        At the coil there is 10.5V and not 7.5V.
        Last time I have checked all the components, except the capacitors.
        The electrolytic ones are Samyoung, which I know they are not good brands, at least in TVs.
        Should I replace them just in case?
        • rievax_60
          • May 2012
          • 897
          • australia
          #64
          I wouldnt bother replacing capacitors at this stage. Is the transistor turning on?
          • tibimakai
            • Jan 2012
            • 3680
            Coming back here.
            That 0.74V it's only there, when I reset the receiver. Otherwise is only 0.003V.
            When I turn on the receiver, the voltage drops to 9.6V and then back to 10.5V.
            I will have to check on the other transistor, I don't remember right now if it's there or not.
            It's clear that Q303 is not getting the signal to turn on the relay.
            It shouldn't turn on the relay when I reset the receiver? That 0.74V it's not enough to turn on the transistor?
            How can I check the relay, if it's good? It has 143 Ohm at the coil.
            • rievax_60
              • May 2012
              • 897
              • australia
              #66
              Coming back here.
              I expect that the relay should be turning on when the receiver is reset. That is the reason the STBY_RLY line is going high for a few seconds.
              Q301's Collector should go from 10.5v to something less than 0.5v.
              Its the voltage that is applied across the coil that matters.
              • tibimakai
                • Jan 2012
                • 3680
                Should I place both probes, over the two coil terminals and measure it that way, while I reset it?
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  #68
                  Yes, if it can be done safely. Did you ever check the voltage change on Q301's Collector?
                  • tibimakai
                    • Jan 2012
                    • 3680
                    At the Collector I measure 0.6V when I reset the receiver.
                    At the coil, I measure 4.5V when I reset it.
                    Q303 is fitted. Voltages are very low, 0.6V, 0.013V, 0V. Doesn't change much, after reset.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      #70
                      If R326 checks ok, try removing the zenner.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #71
                        These readings dont agree with previous readings. You said the voltage at the coil drops from 10.5v to 9.6v.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          The 9.6V is measured from the ground and the 4.5V across the coil.
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #73
                            Those voltages still dont add up right. Replace C301 if nothing else works.
                            I think the relay has a 6 volt coil.
                            We might have reached a dead end.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I will check them again. I have wrote those numbers from memory, I may have missed something.
                              I will replace that capacitor. I know at TVs a bad capacitor can bring down the whole TV.
                              What would happen, if we were closing the contacts of the relay?
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #75
                                If the micro realizes that its not in control of the relay, it might decide to do nothing else.
                                The timing has to be close to right.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have replaced the 2200uF capacitor and it did not help.
                                  OK, I have checked everything again.
                                  At the coil(top part, away from the transistor) is 10.4V in stby and 4.64V after reset.
                                  At the coil connection(transistor Collector) is 10.4V in STBY and 0.6V after reset.
                                  R319 toward the CPU, after reset is 3.1V and at the other end is 0.75V.
                                  Q301 Base is 0.06V, Collector is 10.4V and Emitter os 0V in STBY.
                                  Base is 0.75V, Collector is 0.061V and Emitter is 0V after reset.
                                  What Q303 does? What is PDN?
                                  We have checked the protection modes, if they are turned on or not?
                                  I feel bad about this, that I'm not letting it go. Maybe I should pick up another one and compare them.
                                  There is on on Ebay without HDMI board and amp section, should I pick it up? The problem is that I don't know, what issues has that one also. Maybe bad HDMI board and everything else is good?
                                  I appreciate your help a lot. It seems that only you are helping me in this forum section.
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #77
                                    Q303 signals to the micro that the mains power has been turned off for some reason like a blackout or simply turned off at the outlet. The micro then saves all current settings like Volume and also turns off the speaker relays so the speakers dont thump.
                                    Is R326 ok?
                                    Did you try removing the zenner from across the coil?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I will have to check that resistor. Ones, I have went through all the parts and they all checked out good.
                                      I haven't removed the zenner. Should I try turning on, without it?
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        #79
                                        Yes, Im hoping that the zenner is faulty causing too much current to be bypassed arround the coil. If the relay does work, dont leave it on for more than a few minutes, it might overheat without the zenner.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          The resistor is good.
                                          Zenner diode removal, didn't do anything and it's good too.
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • madsox
                                            Harman Kardon AVR 171S - standby led lights up, does not turn on
                                            by madsox
                                            Greetings!
                                            Thank you in advance for your understanding, I am writing to you through a translator.
                                            A Harman Kardon AVR171S amplifier was given.
                                            The history of the machine is as follows:
                                            It was faulty when I bought it, I want to fix it.
                                            I replaced the HDMI switch and one of the DAC ICs in it.
                                            After that it worked without a problem.
                                            I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                            The cooling was faulty, I will fix this later.
                                            I switched it to standby mode, waited for...
                                            09-24-2022, 10:46 AM
                                          • RatherLoopy
                                            Pioneer VSX-44 receiver HDMI dropouts
                                            by RatherLoopy
                                            I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                            I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                            And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                            05-26-2023, 03:54 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • Doodle43
                                            Samsung LN32B540 - won’t turn on but gets standby power
                                            by Doodle43
                                            My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                            It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                            05-26-2020, 12:02 PM
