Pioneer VSX-1022-K won't turn on
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this receiver to repair it and re-sell it.
    I don't know what caused this issue.
    I have checked the final transistors and they are all good, so the issue it seems that is not a short in the amp area.
    There is a 9 pin connector at the standby board and there I have the standby 3.3V and 10.5V for the CPU_ST_VCC, nothing else.
    I don't get any reaction from the receiver when I turn it on.
    To me it seems like the standby relay is not getting the command from the CPU.
    I never had this type of issue, so I don't know what can I do next.
    Any help would be appreciated.
    SM is available, but is over 33MB. I have found it at elektrotanya.
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Pioneer VSX-1022-K won't turn on
    Some Pioneer models go into a lockdown state when a critical fault is sensed.
    The manual is needed to find how to unlock it and read the diag codes.
    • tibimakai
      • Jan 2012
      • 3680
      There are some functions to clear different errors, but only one did something. Not sure what though.
      It is for clearing DC error, pushing these two buttons Advanced Surround + Standby, I'm getting the setup microphone(MCACC) light to turn on and then off.
      I don't even have the standby light on, so I can't do much from these things from the service menu.
      • rievax_60
        • May 2012
        • 897
        • australia
        Did any relays click?
        • tibimakai
          • Jan 2012
          • 3680
          No. It's completely dead. SM sais that I should have 12V at the HDMI board, but it's missing.
          • tibimakai
            • Jan 2012
            • 3680
            Here is the link from elektrotanya:
            • harish
              • Sep 2012
              • spain
              Try this ALC/standard surr and stanby /On
              • tibimakai
                • Jan 2012
                • 3680
                Thank you,but it doesn't do anything.
                The only reset that does anything is this:
                • tibimakai
                  • Jan 2012
                  • 3680
                  Any more ideas?
                  From the standby board I'm getting 10.5V, that it shouldn't be 12V?
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    Originally posted by tibimakai
                    Any more ideas?
                    There is a 7.5v zenner across the relay coil, so 10.5v could be normal.
                    When you suspect that a rail like this too low, check for excessive ripple that might be caused by a high ESR capacitor or open bridge diode.
                    I get the impression that the System is wanting to turn on the power relay.
                    The display cant work until the main transformer is powered.
                    Is there any voltage activity at each end of R319(near Q301) while you try to wake the receiver.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Hopefully, tomorrow I will have some time to take some measurements.
                      I also have a Rigol 1052 (with the 100MHz hack) scope, but I don't know much about how to use it.
                      Tonight I have played with the repaired Onkyo receiver, there is a lot of setting up to do with one of these. By the way, I'm keeping it and selling the TX-NR609.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        There is no voltage at that resistor.
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          The system control micro will only try to turn the relay on for a few seconds, this is when measurements need to be taken.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I was holding the probes when I plugged it in and turned it on. What kind of voltage should I expect, 5V?
                            • tibimakai
                              • Jan 2012
                              • 3680
                              There are a couple of voltage regulators on the base board, those I guess will receive power only after the relay turns on the main transformer, right?
                              To me, it seems like the turn on signal is not coming from the front plate PCB.
                              I'm not sure what is on that board, it could be the main processor, that controls the receiver?
                              I should remove that board an look at it, maybe I can find some bad fuse or something obviously bad?
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                I would expect momentary 3v on one end of the resistor.
                                Did you also try the Advanced Surround + Standby press?
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  Also try [PRESET k] and [STANDBY/ON]
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Which one is Preset K? There is a Preset left and right arrow.
                                    I have tried both and nothing happened.
                                    Only when I press ADV. Audio+STBY for like 10 sec., then the MCACC light turns on for a couple of seconds.
                                    I have tested all the components on the STBY board and they are all fine.
                                    I haven't seen anything obviously bad on the front panel.
                                    It seems like the Stby and that 10.5V goes to the main processor board on the other side of the receiver and it's plugged in vertically. There are some connectors between this main processor board that are connecting directly into the HDMI board.
                                    I think, that we should concentrate on this processor. Most likely this component should turn on the relay, no?
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      That was supposed to be Preset Left, Its in section 6.1 which you have likely seen.
                                      Because the MCACC light turns on, Im hoping the processor is ok and wanting
                                      to turn on the relay.
                                      You could try tracing the STBY_RLY back to the processor.
                                      Also try to check whats happening at regulators IC101 and IC103 on page 90.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I had a couple of minutes, to check on those two regulators and they seem fishy.
                                        They receive 10.34V, but nothing comes out from them. I assume they are bad, right.
                                        I haven't had time yet to trace the standby relay signal yet.
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • madsox
                                          Harman Kardon AVR 171S - standby led lights up, does not turn on
                                          by madsox
                                          Greetings!
                                          Thank you in advance for your understanding, I am writing to you through a translator.
                                          A Harman Kardon AVR171S amplifier was given.
                                          The history of the machine is as follows:
                                          It was faulty when I bought it, I want to fix it.
                                          I replaced the HDMI switch and one of the DAC ICs in it.
                                          After that it worked without a problem.
                                          I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                          The cooling was faulty, I will fix this later.
                                          I switched it to standby mode, waited for...
                                          09-24-2022, 10:46 AM
                                        • RatherLoopy
                                          Pioneer VSX-44 receiver HDMI dropouts
                                          by RatherLoopy
                                          I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                          I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                          And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                          05-26-2023, 03:54 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • Adenitz
                                          Troubleshooting Vestel TV, has standby, but cannot turn ON
                                          by Adenitz
                                          I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                          Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                          Both boards are shown in the attached photos.
                                          What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                          12-27-2023, 03:43 AM
