Yamaha rx v373 - no power
  • mmoore5553
    • Oct 2013
    • 171
    Re: Yamaha rx v373 - no power
    I am still hunting this down but on IC131 the first leg shows 12 volts when i should have much lower. Anyone have any ideas. I have included schemetic to show all the voltage drops. I tried to look at the pwr_ry but confused on which ic is actually doing that job. i did test most of the IC's out and did a continuity on the legs and they checked out fine.
    • rievax_60
      • May 2012
      • 897
      • australia
      I wouldnt worry about the regulator input voltage being high. The 3.3v output is the important thing.
      • tibimakai
        • Jan 2012
        • 3680
        rievax, this one sounds pretty much the same as my Pioneer.
        I'm still waiting on parts, for both receivers.
        Did you test your final transistors for short?
        • TNathe
          • Jan 2014
          I have a v371 that i beleive took a lightning strike. Just joined this board to learn something and hopefully fix my dead receiver. Mine was in your state, dead. No relay clicks or anything (unless i held down power, and the other 2 buttons to bypass protection mode). Then it would just click on/off
          I replaced c1507 and c1502 last night. I now get the receiver to click on, then about 1 second later it clicks off. So i think i am making progress and it seems my receiver is in the same state as yours. I was going to try replacing the tranformer since i too saw very low resistAnce compared to the 6ohms that one vid said it should have. If i wanted to replace this transformer which one could i use? I cannot locate anything with the same part number.
          • mmoore5553
            • Oct 2013
            • 171
            Sorry wish I could give ya some insight but i went ahead and gave it to a friend. I wish you luck though.
            • TNathe
              • Jan 2014
              Okay, picked me up a good book at the library today after work titled "How To Diagnose And Fix Everything Electronic". It was a great read for any of us beginners who want to learn what it takes to properly troubleshoot an issue.
              I am hoping someone here can give me some direction here. I am tracing the circuit trying to determine where the fault lies.
              SYMPTOM: Power on button causes relay SW151 to switch. About 1 second later the relay will switch back.
              REPLACED SO FAR: Capacitor C1507
              Here is the diagram:
              From my understanding of this transformer, I should be able to test resistance across the "gap" of T1501 (BLUE ARROW). When I test this I get 0.F on the display of the MM. There should be pretty heavy resistance across these paths correct? This is being tested in-circuit btw.
              Thanks guys.
              • YAM373_DLN
                • Apr 2014
                #27
                @mmoore5553
                I have the same defect in my receiver. Did you fix yours?
                You are kind to me and send me the service manual?
                Thank you.
                  • YAM373_DLN
                    • Apr 2014
                    #29
                    I got this: "Error! This file not found! It may deleted or renamed."
                      I saw that now too, I hope other people in this thread will up load the service manual.
                      • YAM373_DLN
                        • Apr 2014
                        #31
                        I hope too, so who has a service manual for Yamaha rx v373, please give me a link or something.
                        Thank you.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Did you guys check that thermal fuse? It can be replaced, you don't need another transformer.
                          Also, from my little experience with these newer Yamaha receivers is, that the receiver needs to be reset to clear the error code(s).
                          • xsony30
                            • Aug 2012
                            • 5
                            • U.S.
                            #33
                            mmoore5533, I have a RX-V373 with the same problem, no power, relay clicks on/off immediately. I found that 3.3vdc supply to IC225 pins 120 and 121 was shorted, causing it to go into protect. Holding down "INFO" AND "TONE CONTROL" while plugging in AC cord cause ac power relay to click. Still trying to find short, I really need diagram of the HDMI/CPU circuit board layout. Do you still have the schematics?
                            • mmoore5553
                              • Oct 2013
                              • 171
                              Sorry, I have search everyone for that manual and i do not have it anymore. I think that is when my laptop crashed. Sorry.
                              • mmoore5553
                                • Oct 2013
                                • 171
                                I found it. Sorry about everyone else asking about it. I never got an email saying this thread was updated.
                                  Thanks!
                                  • xsony30
                                    • Aug 2012
                                    • 5
                                    • U.S.
                                    #37
                                    Thanks for the service manual, mmoore5533. I found the short was in IC202, the HDMI receiver. I tried applying 3.3vdc to the circuit trace after removing Digital board from the unit and the HDMI IC started getting hot, drawing over 5A!
                                    • xsony30
                                      • Aug 2012
                                      • 5
                                      • U.S.
                                      #38
                                      Unfortunately Yamaha has neither the CPU (IC225) or the HDMI IC202, so I am basically s.o. l.
                                        • 31305
                                        so what's the part number for ic202?
                                        • xsony30
                                          • Aug 2012
                                          • 5
                                          • U.S.
                                          #40
                                          It is a Silicon Image SiI9573CTUC, but there is no listing in the parts list. I would not look forward to changing a SMD 176-pin IC.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
