bang olufsen beomaster 4500 no power
  • freakaftr8
    • Oct 2012
    • 3743
    Hello all. Im repairing this unit for a friend. He states that the receiver wont*power*up at all.*I have dc 5v standby to the glass panel and can use my camera phoneto see the ir working under the unit near the ir remote pickup butno*lights whatsoever and buttons will not respond. I only have the receiver and*no*speakers or accessories. When I plug it in I get a click from the*power*supply relay. Thats it.*I'm assuming I'm getting DC filtering from the bridge rectifier or I wouldn't be getting 5 volts to the glass panel or be able to see the IR working underneath the unit. when I receive the unit the glass panel was removed in there were some grounds coming off the main transformer disconnected. When I reconnected them to the frame of tge chassis and plug the unit in I finally have a clicking on the relay. Do I need to have the components connected to this unit in order for it to achieve stand by and us power up by hitting the button.
    Any ideas would be greatly appreciated.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: bang olufsen beomaster 4500 no power
    There are two bridge rectifiers in this unit. Im not gettung any 33 or -33v off the filters.
      Any pictures? It sounds like the standby power supply is working but the main power transformer primary side may not be getting the 120vac feeding it through the relay, cannot tell much until we can see the pictures to know if that is the way this unit is setup. You should be able to turn it on without any speakers or anything connected to the unit beside an AC power.
      • freakaftr8
        • Oct 2012
        • 3743
        Thanks for the tip.
        I ok dug into the thing a little further and I have ac voltage on one side of the r1 but the 9 Volt energizes up on plug in then deenergizes right away so the 9 Volt disappears the coil does not stay latched. The four rectifier diodes on that circuit look like at one point they got extremely hot as the board is very brown around that area but the diodes test good.
          This may help:
          http://elektrotanya.com/?q=showresul...oria=&kat2=all
          • freakaftr8
            • Oct 2012
            • 3743
            Thanks bud. Im suspecting the 4700mfd 16v cap at the moment. It looks unhappy
            • freakaftr8
              • Oct 2012
              • 3743
              Found it. Main processor eeprom. Removable. When removed 9v completes circuit. Eeprom must be corrupted somehow. Battery is good.
              • freakaftr8
                • Oct 2012
                • 3743
                Anyone ever sewn the eeprom get wiped clean before?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Did you ever sort this buddy ?
                    • 31046
                    sounds like his eeprom was shorted out.
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      Really? A two year old thread? He may have been killed by the cops by now. He lives near the prison you know.
                      sigpicThe Sky Is Falling
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        He is on here frequent and I speak to him often. Im just checking is that ok with you ?
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          Have at it. Maybe he'll come back.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Hopefully lol
                            • Longbow
                              • Jun 2011
                              • 623
                              I'm suspicious about the shorted eeprom part. The troubleshooting on this was non-existent. About the only way you could identify a faulty eeprom is if it is actually shorted + to - or if you happen to have a spare one. This was not a part that B&O servicers kept in stock. Typical of this series of offerings, (beomaster, beocord, beogram, etc) they packed a lot into a small attractive cabinet. The heat alone smokes every electrolytic in a short time. Add to that the usual suspects like under rated bridge rectifiers and noisy transistors. Just getting some of these things into the service position takes an origami master.
                              Is it plugged in?
                                • 31046
                                PM the guy - maybe he's got email notifications set.
                                • rhomanski
                                  nowhere man
                                  • 5157
                                  • U S of A
                                  Heh, Heh, he was a little testy with that one. Guess he got in a better mood a little later.
                                  • ZOrd_Z
                                    Bang & Olufsen Beovision Horizon always in standby.
                                    by ZOrd_Z
                                    I every one!!
                                    I have a Bang & Olufsen Beovision Horizon that is always in standby mode ( green light on ).
                                    Main board is 715g7132-m0h-000-005k. Corrupted firmware? I have all the ok voltages in psu.
                                    Any idea?
                                    Thank's...
                                    12-12-2024, 11:44 AM
                                  • ngml
                                    Repair of an LG split AC system indoor unit PCB
                                    by ngml
                                    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                    This indicates an error in the communication between the outdoor and the indoor unit.
                                    The outdoor unit is fine, so the problem is the indoor PCB.
                                    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                    Does anybody have the schematics of this board,...
                                    02-01-2025, 12:55 PM
                                  • dicky96
                                    Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                                    by dicky96
                                    Hi guys
                                    I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                                    If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                                    If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                                    03-24-2023, 06:33 AM
                                  • miketurbo
                                    debug bang and olufsen beomaster 3300 amp model: 2953
                                    by miketurbo
                                    greetings from Westport CT.
                                    I have recently purchased a circa 1986 beosystem 3300.
                                    it worked gloriously for a few hours. then no sound and smell of burnt electronics from the beomaster 3300 amp model: 2953
                                    attached is a bit of the schematic, I have the full pdf schematic if needed.
                                    all, functions aside from sound output seem to still work on the unit. (cd/tape/phono change, display volume display, remote control, radio station, on off etc.
                                    I'm pretty sure the smell was from resistor edit[r122] burning up. (see picture)
                                    I will replace the...
                                    11-16-2021, 05:19 PM
                                  • nobbnobb1
                                    Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                    by nobbnobb1
                                    Hi guys,
                                    Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                    When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                    02-03-2022, 11:14 AM
