Will recapping an ASUS Xonar DG change sound quality?
  • Newbie2
    • Sep 2005
    • 885
    Recently I purchased an inexpensive ASUS Xonar DG PCI sound card, and so far it works nicely, making my games and music sound much better than the VIA VT1708S onboard audio that I had been using for the past few years. However, the capacitors on it are cheap Taiwanese caps:
    * Lelon RGA 100uF 16V 6.3x11mm (x3)
    * Lelon RGA 47uF 25V 5x11mm (x3)
    * Lelon RGA 22uF 16V 5x11mm (x4)
    * Lelon RGA 3.3uF 50V 5x11mm (x6)
    I have placed orders on eBay from different highly-rated sellers for these caps to replace the Lelon caps:
    * Panasonic FC 100uF 25V 6.3x11.2mm
    * Panasonic FC 47uF 35V 6.3x11.2mm
    * Panasonic FC 22uF 50V 5x11mm
    * Panasonic FC 4.7uF 50V 5x11mm
    Now I know that the Panasonic caps are much better in quality compared to the Lelon caps that ASUS uses on the Xonar DG sound cards. However, in general with any sound card, will high-quality low ESR caps actually have any perceivable effect on audio quality compared to cheap general purpose caps?
    I have seen Panasonic FC being mentioned on a few audiophile forum threads as a decent audio cap.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    Back Again?
    • 32761
    Re: Will recapping an ASUS Xonar DG change sound quality?
    Probably not. Audio quality is very subjective.
    Many studies have shown that the average person cannot hear better than 0.01% distortion.
    An average electrolytic capacitor introduces distortion because it has inductance and a dielectric memory effect. A low ESR capacitor such as Panasonic FC will have better parameters in this respect. But, will you hear a difference?
    Think of all of the other imperfections in the system and you'll probably realise it's not worth the effort.
    Most sound cards run off the +/-12V SMPS which is very noisy -- they might include a +/-5V linear reg to chop out some of the noise but quite a lot is still there -- that's the "hiss" you get on quiet sounds. In addition they use low-cost DAC and ADC because to achieve specifications at low cost like 24-bit 192kHz means to sacrifice parameters such as linearity, noise and monotonicity.
    So, all in all, it probably won't make much of a difference, but since audio is one of the most subjective things out there, you MIGHT notice a difference. In which case enjoy it.
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
      Yep, sound is very subjective, the bottom line is, does changing the component make it sound better or worst to YOU is the bottom line. There are so many chains in the audio path from the input all that way to the speaker so look at it as a whole.
      Subscribe to support us and access our Bios, Boardview, schematic search. It only takes 1 minute:
      • rhomanski
        nowhere man
        • 5157
        • Everything
        Compared to the capacitors from thirty+ years ago, it makes a big difference. That's why I use low impedance in old stereos and some low leakage in the audio path. It may just be audible in that as well.
        The Sky Is Falling
        • Khron
          • Sep 2006
          • 1350
          • Finland
          One thing to keep in mind, though - most of the "normal" linear regulator chips might not like too-low an ESR on their output, and might start oscillating. Just to be on the safe side, you might wanna check the datasheets (both for the chip, and the caps)
          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • Newbie2
            • Sep 2005
            • 885
            Thank you for all the responses to my question.
            My primary purpose of replacing the Lelon caps with Panasonic caps was to improve the physical quality of my sound card, with Lelon being a known bad brand, however I was curious whether the Panasonic caps would have any other benefits.
            I will report back on here when I receive all the Panasonic caps and perform the recap.
            My gaming PC:
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              • IT, sound engineering, cycling, drumming, folk dancing, gym, eating, etc...
              Just regular caps don't do much. Audio grade caps do improve sound quality, but they are also much more expensive. A good upgrade would be upgrading the op amp(s).
              Definitely replace the caps in the supply area of your card, that will clean up your audio signal.
              I have a Creative X-Fi XtremeMusic, it's a pretty low fidelity card for music, but after soldering some Sanyo OS-CON caps to the power connector (yes, it actually has a god damn floppy power connector ) my audio signal cleaned up a lot. Also replaced the Jamicon cap for the audio processor with a Rubycon MBZ and again, better sound quality.
              But if you want a real upgrade, replace the op-amp. Depending on the new chip, it can make a HUGE difference.
              I can put text here?!
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                • Power supplies are my primary interest
                Not really on a basic sound card like that. But hey, you've got Panny's on there now You never have to worry about the capacitors failing on it, which is worth the recap in my opinion
                  May be the magic ELNA cap.
                  • Logistics
                    • Apr 2007
                    • 729
                    • DIY Audio/Automotive/Electronics
                    I'm assuming the caps on the left portion of the card are for the output channels. For example, CE13 and CE14 look like the output decoupling caps for the main (green) jack which is for Headphone Out and Line Out, auto-sensing obviously. You could see a benefit by changing these to bipolar (non-polarized) electrolytics. (Panasonic SU) Whether you use bipolars are regulars, you could benefit even further by bypassing each of these capacitors with a small film cap. (think 0.01 uF to 0.1 uF)
                    • Newbie2
                      • Sep 2005
                      • 885
                      I finally had the time to recap my ASUS Xonar DG sound card with the Panasonic FC capacitors I ordered:
                      I don't believe there was any perceivable change in sound quality after replacing the stock Lelon caps with the Panasonic FC caps, however I have peace of mind knowing it's more reliable now.
                      My gaming PC:
                      • lexwalker
                        • Feb 2011
                        • 307
                        • Malaysia
                        Why not try Nichicon KA or Nichicon FG, to see if there are any perceivable differences? Try using Nichicon PW or Nichicon HE on the power supply rails...
                        • DJduck
                          • Dec 2012
                          • 229
                          • Estonia
                          What speakers are you using? When using low quality speakers, You can not get good results with even VERY high end cards.
                          • lti
                            • May 2011
                            • 2572
                            I've seen really bad Chinese caps have an effect on sound quality, but that effect was huge amounts of distortion. Those caps were new and tested good. Lelon caps aren't that bad. They're good enough that you won't notice a difference if you replace them with audio grade caps.
                            • Logistics
                              • Apr 2007
                              • 729
                              If you are simply using the Line-out to an external pair of powered speakers than it will be much harder to tell than if you had compared with headphones which would be directly controlled by the soundcard.
                              • lexwalker
                                • Feb 2011
                                • 307
                                • Malaysia
                                Well, I would replace them if the clients requested for upgrades. Seen plenty of Lelons, especially on JBL units. Usually would use Nichicon KA, Nichicon FG, Nichicon KW, Panasonic ECA, Panasonic HD, etc depending on location in the circuit.
                                • LEECH666
                                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                  by LEECH666
                                  Good day ladies and gentleman!
                                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                  01-19-2024, 05:46 PM
                                • Christos Tsiligiannis
                                  Marian Trace Alpha sound card repair help
                                  by Christos Tsiligiannis
                                  Hello to the forum.
                                  My name is Christos, I am new to the forum here and i am posting from Greece.
                                  So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                  To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                  So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                  11-18-2024, 05:26 AM
                                • Boardview and Schematic Bot
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                  This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-12-2024, 02:30 PM
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
