Just wondering if anyone had the diagram so I can hijack the PCM signal from the built in dvd player and hook up a coaxial input to hook my pc into the Amp portion of the system.
Add Digital input to Sony AVD-K800P
Tags: None
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Add Digital input to Sony AVD-K800P
can anyone have a look at the diagram and let me know what line I should hijack?Comment
Looks like it uses I2S (LRCK, MCLK, etc...) for the internal audio data, which is not compatible with conventional coax audio.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
You'll need an S/PDIF transmitter chip (with the associated circuitry) to make that happen
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
Hi.
I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
Where in the circuit is the best place to solder the 3 stereo input wires?
This is the model and schematics:
https://www.manualslib.com/manual/91...7l.html#manual-
by UserXPDear all,
I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
My question is, do you know of this brand of capacitors and how bad are...-
by ugamazingSo, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not... -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
Also fixed A LOT of cold solder joints and also done some modifications,...-
- Loading...
