Recap of Pioneer SX-750
  • andycap
    • Dec 2006
    • 14
    Wow! My first post and what an informative site. Luckily, my Abit BD7-Raid hasn't needed new caps (thumbs up to Rubycon)!
    However, my Pioneer SX-750 receiver is ready for some power supply caps. Not bad for a receiver almost 30 years old. Can anybody recommend some high quality caps in the 15000uF 50v spec. My first choice was some Nichicon PW series but I can't find any in this spec.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Recap of Pioneer SX-750
    http://www.nichicon-us.com/english/s...arg/list_f.htm
    select LS series
    http://www.rubycon.co.jp/en/catalog/capacitors.html
    Select USC series
    http://www.chemi-con.co.jp/english/catalog_e/top.html
    Select SMH series
    PeteS in CA
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      also nichicon muse.iirc its kz series.
      the kg is for audio apps too.
      • andycap
        • Dec 2006
        • 14
        Thanks!
        • Brian C
          • Dec 2006
          • 156
          The sound of nichicon (fine gold) series cap are "dry" .... I prefer elna cerafine or silmic, it sounds nicer.
          Or... Rubycon "Black Gate" ---- if u can afford.
          • andycap
            • Dec 2006
            • 14
            Black Gates are over priced and I can't find Elna's with my required spec of 15KuF - 50V. The Nichicon's will have to do.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              I'd be interested to see how this turns out. I've been thinking of recapping my SX-450. When I turn it on, it emits static from the speakers and the front panel lights flicker to the buzzing until suddenly it flicks on solid. Works fine after that, so I'm thinking it might be one of the caps not taking the charge or something.
              Ludicrous gibs!
              • Brian C
                • Dec 2006
                • 156
                Elna audio grade capacitor. My preference for audio equipment.
                • andycap
                  • Dec 2006
                  • 14
                  That's pretty much what my SX-750 was doing. One of the 15KuF - 50V caps had vented (must of been a while since it was all dried up). What's cheesy about the SX-750 is the main power supply caps (2 of them) are wired in series. Don't know about the other SX models though.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    sounds like a bad switch or something loose at the ac input.
                    possible fire hazard.
                    • andycap
                      • Dec 2006
                      • 14
                      Turned out excellent! I went with Nichicon Gold KG's. Now, when the Pioneer gets a base signal, the panel lights don't dim. Very happy, and nice caps at that.
                      • gdement
                        • Jan 2007
                        • 690
                        Glad to hear it. I (like dood) have an SX-450 that I'd like to try recapping sometime. The volume knob makes scratching noises when first turned on, and one of the stereo channels intermittently drops to very low volume. Hitting it seems to help.
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          That's not the caps, mate... that's the controls. Go get yourself some good contact cleaner, pull that puppy apart, and douse the hell out of the controls. MAKE SURE THE UNIT IS UNPLUGGED!
                          Start at one end and work your way over. Spray the cleaner as far into the pot as you can, while working it back and forth from stop to stop. Most likely, the contacts inside are just corroded. ESPECIALLY on the volume and balance knobs. The only thing I haven't figured out yet on mine (other than the earlier mentioned turn-on problem) is that the one channel with drop out, and messing around with the mono switch will sometimes bring it back. I can't get to that switch to clean it, if I remember correctly. I dunno, it's been a long time since I've had mine open
                          Ludicrous gibs!
                          • gdement
                            • Jan 2007
                            • 690
                            The dropped out stereo channel is what really bothers me, the volume scratching only happens when I first turn it on so no big deal. I'm not sure if we have the same dropout problem or not - I can also get both speakers back by using the mono switch, but the missing channel is still missing when I do that. I just get the working channel x 2.
                            Usually the left drops out, but I think I've had the right go out sometimes, and even both of them dropped out very rarely.
                            I use it mostly on headphones nowadays and haven't noticed the dropout nearly as often, but that might just be a coincidence.
                            I should certainly try cleaning the controls sometime, that should at least fix the volume scratch. I have no idea if new capacitors would help anything or not, but after this many years I figure it couldn't hurt.
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              That's true... it's really not going to hurt it any to get new caps. I'd still look to cleaning the controls up to fix your channel dropout problem. If you get both channels back when you hit the mono button, then your amp output stage is working fine. The issue is that the dropped signal isn't even making it to the amp. Meaning, it's a source issue, and that usually points to corroded connections in the back, a dirty source switch, or a dirty balance knob. I'd bet cleaning will help a lot!!!
                              Ludicrous gibs!
                              • RatherLoopy
                                Pioneer VSX-44 receiver HDMI dropouts
                                by RatherLoopy
                                I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                05-26-2023, 03:54 PM
                              • pulper111
                                Pioneer VSX-1123 Receiver - weird voltage problem
                                by pulper111
                                Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                                I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                                09-02-2020, 11:12 AM
                              • thetonywarren
                                Pioneer VSX-3300 Receiver Wont Power On
                                by thetonywarren
                                Have a colleagues Pioneer VSX-3300, it wont power on, hasnt for a number of years, but just now trying to figure out what's going on with it.
                                It has 120V input and I have followed that 120V to a small board that appears to have a small transformer and a relay among a few other components I dont think the relay is changing state which I believe turns on the receiver, but this is all speculation.....
                                I have downloaded the repair guide, which I have attached to this post, but I am having a hard time following it.... Can someone please offer any advice on what to check?...
                                12-28-2021, 01:26 PM
                              • spiros.p
                                Pioneer DJM-800 recap
                                by spiros.p
                                point of interest i recap my 14years old djm800 psu.last 2-3 months gets too hot the mixer on psu side.open it after two hours of use and touch the big filter cap and the near mosfet heat sink was very hot.under the board i see three hot spots that is discolored from excessive heat. replace all caps with nichicon GU big filter cap and all the others with nichicon KY and panasonic FR now is running cool and sounds better.
                                07-28-2022, 02:17 AM
                              • wolf1976
                                wireless receiver for 6 speeds fan control with remote control
                                by wolf1976
                                hi i have a receiver that is destroyed from the overvoltage i guess
                                my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                the motor fan has not label
                                i have an other receiver operational
                                In your opinion can i measure the voltage at the output ?
                                what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                thanks in advance...
                                07-23-2025, 03:12 PM
