AEG CS MP300 Input mod?
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    I got an Aeg car stereo from a friend, it had a blown 78l18 and 1n5401 which I both replaced. I want to use it as an amplifier to power some Sony bookshelf speakers and to have an input signal from my PC. It has no input jacks or cd changer inputs, and I tried to locate the output wires on the CD drive ribbon cable, but they are not marked, and I can't find the service manual. There are some unused solder holes for connectors that are not included:
    8 pins: AG, LCH, RCH, G2, BUS, G1, ODC, CDCON
    3 PINS: AUX-G, AUX-R, AUX-L
    MAINBOARD: 11-02001-005 CD-200 (4X7W) MB VER.e SIDE-A
    Any of these pins useful? Or just solder the input jack to the input pins on the SC
    7313S? Or the inputs on the TDA7377? Need help please! It's a nice little stereo, has some Samxon caps, and some no-name crap, that i'm going to replace with Rubycon and Elna.
    I can put text here?!
    Re: AEG CS MP300 Input mod?
    "AUX-G, AUX-R, AUX-L" That must be for the Aux INPUT.
    AUX-G is common ground for the AUX input.
    AUX-R is AUX input Right
    AUX-L is AUX input Left.
    But can you do any input select using the control panel?
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Nope, I do not think i can do any selection. I might just solder ln a 3.5mm and see what it does. It does have some AUX on the main back panel connector, but they are outputs. The 3pin missing aux also has some SMD caps and resistors missing, Should i put them on? Or if you could help me with the CD output, that would be awesome, since the CD player is toasted anyway. I actually don't want to just solder the wires directly to the TDA7377, since I won't be able to use the volume control.
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        Got the cd drive working at least, so it's somewhat useful now. And the 8pin missing piece is probaly a CD changer input, which could also be used, just solder the wires to AG, RCH AND KCH.
        • Tarot Superstars
          Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
          by Tarot Superstars
          Hi.
          I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
          Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
          Where in the circuit is the best place to solder the 3 stereo input wires?
          This is the model and schematics:
          https://www.manualslib.com/manual/91...7l.html#manual
          10-31-2023, 03:23 AM
        • ugamazing
          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
          by ugamazing
          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
          04-10-2024, 08:06 AM
        • corrize
          Where to find a very small fpc connector 0.3mm between 2 pins ?
          by corrize
          Hello, I search this connector (oxydated).
          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
          Do you know how to find this connector please ? What is the exact name for find it ?
          08-06-2024, 05:25 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • redbaron1007
          Crua CR270C shorted input.
          by redbaron1007
          I've got a Crua CR270C that had a short to ground on the input jack. The input was rated at 12v 4A center pin positive. When I took the board out and powered it with my bench power supply it jumped to 3v and 4A CC and a chip labeled either TM3db2 or TV3db2. I'm not able to find anything online typing in those strings of letters and numbers and searching websites like s-manuals hasn't yielded anything. It is an sot23-6 package type according to my digikey ruler and I was able to work out some of the pinout from voltages on the board and following the traces around. I'm not really sure what a suitable...
          03-12-2025, 02:10 PM
