AEG CS MP300 Input mod?
    I got an Aeg car stereo from a friend, it had a blown 78l18 and 1n5401 which I both replaced. I want to use it as an amplifier to power some Sony bookshelf speakers and to have an input signal from my PC. It has no input jacks or cd changer inputs, and I tried to locate the output wires on the CD drive ribbon cable, but they are not marked, and I can't find the service manual. There are some unused solder holes for connectors that are not included:
    8 pins: AG, LCH, RCH, G2, BUS, G1, ODC, CDCON
    3 PINS: AUX-G, AUX-R, AUX-L
    MAINBOARD: 11-02001-005 CD-200 (4X7W) MB VER.e SIDE-A
    Any of these pins useful? Or just solder the input jack to the input pins on the SC
    7313S? Or the inputs on the TDA7377? Need help please! It's a nice little stereo, has some Samxon caps, and some no-name crap, that i'm going to replace with Rubycon and Elna.
    I can put text here?!
    Re: AEG CS MP300 Input mod?
    "AUX-G, AUX-R, AUX-L" That must be for the Aux INPUT.
    AUX-G is common ground for the AUX input.
    AUX-R is AUX input Right
    AUX-L is AUX input Left.
    But can you do any input select using the control panel?
      Nope, I do not think i can do any selection. I might just solder ln a 3.5mm and see what it does. It does have some AUX on the main back panel connector, but they are outputs. The 3pin missing aux also has some SMD caps and resistors missing, Should i put them on? Or if you could help me with the CD output, that would be awesome, since the CD player is toasted anyway. I actually don't want to just solder the wires directly to the TDA7377, since I won't be able to use the volume control.
        Got the cd drive working at least, so it's somewhat useful now. And the 8pin missing piece is probaly a CD changer input, which could also be used, just solder the wires to AG, RCH AND KCH.
