HH Electronic MX1200 Power Amplifier Fuse shorted
  • 9w2tzw
    • May 2013
    • 14
    • Malaysia
    Currently i got one unit of HH Electronic MX1200 power amplifier.it can be turned on without any indicator of protect LED being in ON state.But the problem is, it can't detect any input signal.So, when i open the cover, i noticed that the 1A fuse of both channel keep blown even i had replaced it.Original owner said it the power amp has gone down since he "misshorted" the + and - terminal of the speaker.Any idea? by the way i had attached the schematic for reference.
    It uses 10 pair of BUZ901 and BUZ906 Mosfet transistor.total 20 for both channel.
    Learn a Little but Often,
    Practice Makes Perfect,
    Repetition is the Key of Success,
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: HH Electronic MX1200 Power Amplifier Fuse shorted
    The 1A fuse is for the 70v rail as per the schematic. Measure between either end of the fuse holder and ground. You'll find one of the ends is shorted. Then it's a matter of tracing thru the circuit and see which part has caused the short.
    Also, have you checked the output transistors already? If they are blown, it's gonna be an expensive repair.
    A word of warning: This power amplifier uses high voltage rails and has large capacitors. Make sure the main capacitors are discharged prior to attempting any work on this unit, otherwise serious damage to you, your tools, or the amplifier itself may occur.
    If the caps still show over 30 volts after several minutes after unplugging the unit, use a regular mains voltage lightbulb to discharge them.
    A working TV? How boring!
    • 9w2tzw
      • May 2013
      • 14
      • Malaysia
      i had 2 times replacing the fuse.and they both got blown after i powered on the unit.
      thanks for reminder, can i use 82 ohm 5 watt resistor to discharge the capacitor?for smaller capacitor, i use this method to discharge them.
      i still dont know the exact ways to test the mosfet transistor.any guide?
        Did you check the 4 1n4007 D40~D43 to see if they are shorted out?
        If the MOSFETs shorted out the fuses FS1~FS4 will blow also.
          • 9w2tzw
            • May 2013
            • 14
            • Malaysia
            D40-D43 i had checked and they just doing fine.
            How to tests out the MOSFETs shorted or not? Thanks for reply
            • rievax_60
              • May 2012
              • 897
              • australia
              There is no reason to suspect the MOSFETs at this stage. Are there shorts to 0v on the VS2 rails?
                Then check the resistance reading on the output of the D40~D43 (full bridge setup) output to see if they are feeding shorted loads. You have shorted circuits that are causing the fuses to blow.
                "D40-D43 i had checked and they just doing fine" What are the readings?
                You are using Time Delayed fuses, right?
                • 9w2tzw
                  • May 2013
                  • 14
                  • Malaysia
                  I cannot managed to get reading at ON State since i am not using time delayed fuses.I just use normal 1A fuses since at my area are hardly enough to get this type of fuses.During OFF state, i managed to get 0.45 /0.47 V at all diodes , D40-D43.
                  • 9w2tzw
                    • May 2013
                    • 14
                    • Malaysia
                    any helps?
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      any helps?
                      Check transistors T3, T4, T5, T8, T9, and T10 for shorts (desolder them from the board if you aren't sure if they are shorted or not, then measure them)
                      I think it's highly likely that at least one of them will be shorted out.
                      Muh-soggy-knee
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • mkdj
                        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                        by mkdj
                        Dear all,
                        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                        Both N-Channel Mosfets: nothing odd
                        P-Channel MOSFET number 1:
                        source - drain : 117 kOhm
                        source - gate: 96 Ohm
                        gate - drain: 117 kOhm
                        P-Channel MOSFET...
                        08-20-2025, 06:08 AM
