Ashly GQX 3101 31 Band EQ Restoration
  • 9w2tzw
    • May 2013
    • 14
    • Malaysia
    Hello there,
    Since i am new to this forum, and i thought that i want to share a little bit of my experience restoring this Ashly GQX3101 EQ. The original owner is happen to be Goverment of Malaysia , and by specifically owned by gov school at my area since 1993 . This problem with this EQ , its cannot detect any input signal from all the jack / port available.In order to fix this, i had googled the service manual / any schematics available to fix this problem.For almost 4 years i tried to find both of the documents, and guess what? i got nothing. One week before, around 21 / 05 / 2013, i random watch youtube videos about electronics ( * since i am abducted with electronics and currently now taking diploma in electronics engineering (computer ), now in last semester ( sem 6 ), i found one great channel , username " Maxxarcade ", i and had almost learn everything that basic electronic which i had never learnt during my diploma.He also make me inspired to repair back this EQ after 4 years.Since Ashly had discontinued production of this unit,to try my luck, i had contacted Ashly technical person, named Jim Schwenzer asking for schematic.In my mind, i just thought that i would possibbly waste my time asking for schematics since i cannot found anywhere on the net.
    Just a few minutes after i send the email, Jim had replied my email with the schematics and also few problem that maybe connected to the problem.Initially, i thought the op amp was broken / damaged .Since i had test at diode at the voltage regulator, i got -18V at 7818 negative voltage regulator and 0V at the 7918 voltage regulator.After searching around the board doing some checking at the Electrolytic cap, they all seems fine.Rubycon brand.
    Guess what happened?
    The polyster film capacitor 0.1uF had caused the problem.Even though the EQ can be powered on, the "shorted" capacitor had caused the 7918 positive voltage regulator reads 0V instead of 18V as it should be.
    After replacing the "shorted" capacitor, the EQ now runs smoothly without any other problem and sounds perfect !.
    And, i want to thanks " Maxxarcade " for uploading such a educational video even though he just said its for fun . You had saved my day ! Thanks again. Not forget, Jim Schwenzer from Ashly Technical Service for the schematic and tips.
    I had attached the schematic of Ashly GQX3101 schematic if anyone else had this EQ for repair or future reference can used it at ease.Sorry for my broken English. I hope you guys dont mind.Thanks again.
    Learn a Little but Often,
    Practice Makes Perfect,
    Repetition is the Key of Success,
    Re: Ashly GQX 3101 31 Band EQ Restoration
    Great to hear! It is unusual to see polyester cap go short.
    Only one correction: 7818 is positive, 7918 is negative.
    It's nice when manufacturers provide schematics -- most of them closely guard them as secrets! I think schematics should be provided for all electronics after warranties expire.
    • 9w2tzw
      • May 2013
      • 14
      • Malaysia
      yeah.sorry for that.my mistake
      firstly i just thought the electrolytics had gone bad, but it appearently to be opposite.anyway, i too happy this week since it came back to life.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        C302, the blue one, looks "suspiciously" like a ceramic, not a polyester cap. It's too small
        And ceramics HAVE been known to fail shorted...
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Yes it is a multilayer ceramic capacitor. Like these, but colored blue instead of yellow in the image.
          Multilayer ceramic capacitors are more prone to cracking inside, causing short circuits.
          Muh-soggy-knee
          • howardc64
            LG 49UJ6500 LCD panel lighter band that goes away
            by howardc64
            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
            02-19-2023, 12:13 AM
          • Chaks
            Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
            by Chaks
            TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
            The specs says ...
            High antenna efficiency 868MHz ISM Band
            5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
            The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
            1. Should I Fix it with a glue.
            2. Should I fix it with a double side adhesive tape
            3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
            12-09-2024, 11:06 AM
          • Askic
            Reading resistor value by color band
            by Askic
            attached is a picture with two resistors. I wonder what values are based on color of the band.
            I have used this as a reference:
            https://www.electronics-tutorials.ws...tor/res_2.html
            Since there are 5 bands, the question is from where to start counting (what is the first band).
            Based on this info, I can conclude that thick band is the last one.
            Therefore the values are:
            Left resistor - red(2) yellow(4) black(0) black (x1) brown (1% tol) = 240 ohm, 1% tolerance
            Right resistor - brown(1) black(0) black(0) gold(x0.1)...
            02-10-2022, 12:26 AM
          • AJ2021
            Sharp LC80UH30U Vertical Band
            by AJ2021
            I just moved to a new apartment and now I got a vertical band on my tv. The band is changing colors all the time. Is there a fix for this? If someone has had the same problem and fixed it I would really appreciate the help as I am retired and on a fixed income and cannot afford a new tv.
            I can change any boards and bad caps but I'm not good with a volt meter.
            Thank you very much for any assistance....
            01-30-2022, 10:57 AM
          • badcapspirate
            LG 55LM9600 Dark Band Artifacting
            by badcapspirate
            I love this TV. I have had it for about five years and about a year ago the audio went out and I reflowed the motherboard with success. I just went on vacation and came back to the following. Because I have nothing to lose I have already tried to reflow the motherboard and the tcon with no success. Parts are available and I'm open to ordering them just not sure what the issue really is. The band has a very distinct cut off on the bottom but a gentle fade to the left. There is artifacting that appears underneath the band. It's possible to watch a show but the colors are a little bit off on the...
            11-12-2021, 06:59 PM
