Problem with an XSITE XAD2K vehicle amp
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Got this repair for a client and need a clue.
    Who has a good 2200uF cap at 80 volts that will fit in a space of 1.02 inches round by 1.22 inches tall.
    This thing lunched three of these, if I have to take it all apart, Im going to change every last one.
    Open to ideas.
    If you need photography that is not hard to do.
    Mike
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
  • japlytic
    • Oct 2005
    • 2086
    Re: Problem with an XSITE XAD2K vehicle amp
    I found that an 85C Chemi-Con SMH (part ESMH800VSN222MQ30S) would fit - what is the temperature of the original units?
    • Jack Crow
      It's a CLASOB!
      • May 2008
      • 823
      J,
      Taught me something new.
      I never noticed a temp rating on the on the parts, but it's there.
      It reads 85 degrees C.
      I found some parts that would fit on Mouser for about 4 bucks each.
      The next problem was how to get the board out.
      The transistors are held to the heat sink by some very stout spring clips.
      With a stiff screw driver I can bend the clip out of the way, but there are 7 clips on one side, and 9 on the other.
      They have no interest in sliding out of their positions, it's as if they were press fit into place.
      Is there a special tool I can buy to release these clips?
      Thanks in advance.
      Jack Crow
      The Masso
      Mayor John Almafi
      MC Hawking
      • Jack Crow
        It's a CLASOB!
        • May 2008
        • 823
        J
        As one of the gun guys I know is fond of saying....
        "This post is worthless w/o pictures".
        Just took some.
        http://www.flickr.com/photos/9010884...th/8095470001/
        Let me know what you think.
        Im stuck on how to remove those clips.
        Jack Crow
        The Masso
        Mayor John Almafi
        MC Hawking
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          they should just pull up.
          if you can get 105c caps do it.
          they have a rough life in boom car amps.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Interesting 'DKE' brand caps!
            It looks like somehow to clips go into the heatsink. Do they get screwed down on the back of the heatsink? Are they bent over the back of the heatsink? (I.E. do they have a little tab -that goes into a hole in the back of the heatsink- which is bent over?)
            Muh-soggy-knee
            • gilly1984
              • Jun 2012
              • 751
              them clips are a pain to get off. use a flat head screwdriver and just keep teasing each clip, they will pop off. hurts your palm when putting them back on.
              Do NOT touch heatsinks when testing for voltages as they may be LIVE!
              • Jack Crow
                It's a CLASOB!
                • May 2008
                • 823
                Ben, KC8 and Gil,
                They slot into the main heat sink, no screws or hardware.
                One of my buds in the auto sound biz said to drop some oil into the joint.
                That is good thinking.
                Steel clip in an aluminum heat sink is a recipe for bi metallic problems.
                Will make the run to Home Depot (US based hardware store chain) up the road and buy a stout screw driver.
                I think I can make due with the 'needle nose' vice grips I already have.
                Getting the clips back on, is going to be a cast iron female hound.
                Guys, Thanks for the tips, will give it a try.
                Jack Crow
                The Masso
                Mayor John Almafi
                MC Hawking
                • Jack Crow
                  It's a CLASOB!
                  • May 2008
                  • 823
                  Guys,
                  The tool dealer paid off.
                  Got some bigger tools and that seems to have been the trick.
                  The board came right out.
                  New photos are at the end of the current set. The last five. The first few are going to be 're runs'.
                  http://www.flickr.com/photos/9010884...7631787506891/
                  That nasty hooked tool is for removing cotter pins.
                  Might be better for forcing confessions from them.
                  Anyhow, the board is out, I pulled the six caps that looked bulged.
                  They are split three and three. Popped and more or less working according to my esr meter.
                  So if this is a bi polar supply, one side failed hard.
                  Over the weekend I am going to check the transistors (lots of power fets) and the fast recovery diodes. My gut says ripple blew the caps.
                  Some surprises.
                  The board is flimsy. If im not real careful I can snap it. There is a huge amount of weight with the transformers but still.
                  The gauge reads .07 inches.
                  Another thing is the fusing. It has five 'thirty amp' fuses in parallel.
                  That is a lot of dam current. My bench supply is good for about 30 amps.
                  Last item, the board was less than clean. As if the OEM failed to remove the flux. Gross. At least it cleaned up in Iso Alcohol.
                  That is the news of the moment.
                  Dreading the time when the clips need to go back on.
                  Keep it safe
                  Jack Crow
                  The Masso
                  Mayor John Almafi
                  MC Hawking
                  • Jack Crow
                    It's a CLASOB!
                    • May 2008
                    • 823
                    Follow ups.
                    Installed the caps today. Ended up using six of the puppies.
                    (CDM 380LX 2200uF 80WV +85 degree C units. )
                    Cut off the excess lead length.
                    Cleaned the circuit board.
                    Figured out how to put the spring clips back on the power transistors.
                    (Drive bar and a tap hammer!)
                    Had to fabricate up some harness wires for testing.
                    First to feed my audio generator into this things RCA inputs.
                    Then to hook up the power feed to my bench systems plus a remote switch simulator.
                    Fired the thing up.
                    It seems to work.
                    No explosions.
                    No sparks.
                    No smoke.
                    Not at all what I call exciting.
                    What I can't find is my audio power load.
                    So with very little in the input (aprox -30dB), centered at 40hz I get a huge amount of open circuit output.
                    In the range of 50 volts.
                    That is a lot of gain.
                    Then again this thing is some kind of 'sub amp'.
                    That will drop a bit when I get a load on it.
                    Going to let it run for a few hours on the bench to make sure the new caps stay good.
                    This was a different kind of assignment for me.
                    When I play in audio it's with more or less normal stereo gear, dedicated sub amps are something I just going to have to get used to.
                    Thanks to one and all for the inputs and insights.
                    Keep it safe
                    Jack Crow
                    The Masso
                    Mayor John Almafi
                    MC Hawking
                    • redwire
                      • Dec 2010
                      • 3912
                      Great pics and repair work, that's quite a big car amp. I haven't seen dual-transformers or 5-pair output transistors in a car amp. That's enough to destroy my eardrums....
                      What replacement caps did you end up using?
                      • redwire
                        • Dec 2010
                        • 3912
                        Oops, I just saw the Cornell Dubilier part#CDM 380LX 2200uF 80WV +85C you used. Had no idea they made small, low profile parts. I think they are among the best for this application.
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • Zeonalbasta
                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                          by Zeonalbasta
                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                          09-13-2024, 01:17 PM
                        • Gibon378
                          Problem with stopping audio and video for no reason
                          by Gibon378
                          PC Specs:
                          • CPU: Ryzen 5 1600
                          • GPU: GTX 1080 Palit JetStream
                          • MOBO: ASRock ab350 PRO4
                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                          • PSU: XFX 650W (don't remember what model)
                          • OS SSD: ADATA SP920
                          • OS: Windows 10 21H2
                          Problem description:
                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                          11-19-2022, 09:41 AM
                        • BOSCHNJAK
                          by BOSCHNJAK
                          ABOUT ME INTRODUCTION FILE
                          2
                          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                          2022 BEV, PROJECT ?
                          2021 BEV, PROJECT ?
                          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                          12-28-2023, 02:09 PM
                        • perzyk23
                          Lenovo T580 - LCD Panel problem - error 0288
                          by perzyk23
                          Good morning,
                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                          10-25-2024, 12:42 AM
