Adding a volume control
  • HotHead
    • Mar 2011
    • 43
    Hi
    I have a Craig cht742 subwoofer (output 30w) and speakers. The volume used to be controlled by the receiver but the receiver is no longer working.
    I'd like to use the speakers connected directly to the tv audio out but they play at full volume when powered on.
    Is there a simple way to solder a volume control directly to the sub and control all out audio?
    Any help or direction would be appreciated.
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: Adding a volume control
    I'm not quite sure what exactly you're trying to do. Is the TV going to be sending the audio output to the subwoofer and then the subwoofer to the speakers? Also is there an amplifier in the subwoofer?
      Can you post the pictures?
      • 999999999
        • Sep 2006
        • 774
        More detail may help, all of the following could be wrong.
        Is the amp for the satellites built into the sub? Since you wrote they play at full volume, implying that's pretty loud, I'll assume so. I'm also assuming the TV outputs a line level signal that is non-adjustable from the TV menu or remote.
        Do you need independent adjustments for left, right, both front and rear, and center? If so, it is quite a bit more complex to do, then you'll have to reverse engineer the circuits used, break traces and tap into those at the appropriate portions of each subcircuit to add pots.
        If not, if an equal reduction in volume is acceptable, then yes you can add a stereo (preferably log not linear...) potentiometer between the audio input jacks on the sub and the rest of the circuit. You might even be able to just salvage the pot out of the receiver and put it in the sub. "IF" the amp placement is as I suggested above then it may only be moving the pot from before the length of audio cable connecting the two, to after it (substituting TV as source).
        • HotHead
          • Mar 2011
          • 43
          Thank-you for the replies and here are a few pictures. I hope they are clear enough.
          momaka, yes the t.v. will be sending the audio to the sub (2-ch) and then the sub to the speakers. I believe it does amplify.
          999999999, i do believe that the amp for the speakers are in the sub, new here so forgive me if i am wrong but the amp is the 7ic s at the bottom. No? The output audio of the t.v. through the jacks are not adjustable from the remote or t.v. menu.
          I don't think i'll need independent adjustments as i will not be using the 5.1 but only the 2-ch option. I think trying to tamper with the 5.1 would be out of my league, for now.
          An equal reduction is what i am looking to achieve but wasn't sure if it was possible to just add a pot before the cable goes into the sub and have it work. Also would a 25k pot(stereo, log) be sufficient?
          Again, thanks for the help.
          • 999999999
            • Sep 2006
            • 774
            Yes you can use a 25K dual gang log pot, or even two separate 25K single gang log pots for some attenuation of L vs R channel. Personally, I'd just drill a hole in the sub housing or back-plate and mount it there rather than having to build a separate box with connectors to have it before the cable gets to the sub, but either way would work.
            Having it in the rear does seem less convenient since you're going to have to go over and adjust that knob any time you want the volume to change.
              Does your TV has headphone output? What brand id the TV?
              The 7 ICs in the units are for sub woofer and 5 speakers (2 IC are setup as bridge output for driving the sub woofer speaker, the other 5 are one IC per speaker, 5 speakers).
              • crackedprint
                Sony HCD-HX80R Amplifier Volume Control Problem
                by crackedprint
                I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                I have tried a Cold Reset as per the service manual.
                I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                I have looked all the way through the service manual and tried many online...
                01-21-2025, 12:18 PM
              • wolf1976
                wireless receiver for 6 speeds fan control with remote control
                by wolf1976
                hi i have a receiver that is destroyed from the overvoltage i guess
                my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                the motor fan has not label
                i have an other receiver operational
                In your opinion can i measure the voltage at the output ?
                what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                thanks in advance...
                07-23-2025, 03:12 PM
              • redwire
                Onkyo TX-SR607 replacement volume control encoder
                by redwire
                I had an Onkyo SR607 with a volume control encoder not working, turning the knob up the volume number would move around crazy and not work reliably.
                Took it out and apart and no, it's not oxide or cleaning, lube required etc.- the metal is simply worn out. It's a 30mm part with metal bushing.
                Volume control encoder Onkyo P/N 25065655W, Alps EC12E2425 is some oddball variant I could not find. I did the dig and tried replacement part Alps EC12E2420803 and it works/fits just like the original. Mouser 688-EC12E2420803 for $3.00
                09-09-2022, 08:59 PM
              • madan1
                Cambridge Audio azur 540r volume control problem
                by madan1
                Hi everyone.
                I have a Cambridge Audio azur 540r and face the following problem - from time to time the volume can be set only to VOL MIN and VOL MAX ( from both the volume knob and the remote ).
                The volume control IC is BD3816K1 and it is controlled by the CPU M5964C40J.
                The volume knob VOL_A and VOL_B signal enters the CPU and is processed to VOL_DATA and VOL_CLK which go straight to the volume control IC ( I believe the remote control signal also goes the same way ).
                The CPU is powered by a stand-by transformer with constant +5V ( 7805 ).
                The VOL IC
                11-01-2018, 12:55 AM
              • tmhobadcap
                Pioneer VSX-522-K remote control not working???
                by tmhobadcap
                I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                12-24-2020, 01:44 AM
