Focusrite Saffire Pro 40 re-cap
  • hardsmoker
    • Apr 2014
    • Indonesia
    #81
    Re: Focusrite Saffire Pro 40 re-cap
    hi i have a problem with my FOCUSRITE Saffire Pro 40, the technician said that the problem is in the power supply, can you please help me to get the original schematic that contain parts of the power supply? thank you
    • Khron
      • Sep 2006
      • 1350
      • Finland
      #82
      And what exactly is that problem?
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • hardsmoker
        • Apr 2014
        • Indonesia
        #83
        the problem is my technician wanted me to buy MOSFETs, but the type of the mosfet that I do not know. at least I could know the type so that I can buy at my local store. thanks for the reply Khron666
        • Khron
          • Sep 2006
          • 1350
          • Finland
          #84
          Well, as you can read in the initial post, the stock FET was a FairchildSemi FQPF8N60C. Characteristics you'll want to care about if you need to replace it with a different part number, would be:
          Vdss = 600v or more
          Id = 7A or more
          Qg = 40nC or less
          or
          Ciss = 1200pF or less
          • hardsmoker
            • Apr 2014
            • Indonesia
            #85
            All right, thanks so much for your information. I hope it will help me in improving my focusrite Saffire Pro 40. Good luck to you Khron666 \m/
            • Khron
              • Sep 2006
              • 1350
              • Finland
              #86
              Getting the power supply working again definitely WILL improve your 40 Not 10000% sure about the rest, though - i did it more as a "peace of mind"-project. Although i do still have replacement opamps in stock...
              • ludwigvanlee
                • Jul 2014
                • Viet Nam
                #87
                I read through what you guys did, woah.. awesome!
                I'm quite the noob but I ever since a few months ago when I heard about modding, I became really interested in it though I do not have a background in it.
                My question would this be easy to learn to do? I myself do not have experiencing modding audio equipment but I know someone who has experience building and fixing audio gear (though mostly inexpensive). What I was thinking was buying the materials you guys listed here then having my friend help me with it.
                Would you guys recommend that?
                • jayache80
                  • Jun 2014
                  Hi ludwigvanlee,
                  I wanted to say that I'm in a similar boat. I have experience soldering and building stuff out, however I've never been happy with my repair work, often burning PCBs or melting insulation... What I'm going to do is buy a hot air rework station first thing, and practice on electronics that I don't care about- taking ICs off and putting on new ones. Once I feel comfortable, I'll dig into the Saffire Pro40. My channel 8 mysteriously stopped working after feeding it some pretty hot audio (0dbFS and up) and that's how I found this thread. I don't believe it should've blown so easily, but alas it did and I think I'll just replace the ICs on that channel and have an "upgraded" channel. If I like the mod, I can do more channels!
                  • Khron
                    • Sep 2006
                    • 1350
                    • Finland
                    #89
                    Hint: yes, a hot-air station is quite mandatory to be able to get surface-mount IC's off boards, but soldering them back on is a breeze with a half-decent temperature-controlled soldering iron
                    Just try to put some Kapton or aluminium tape, for heat-shielding, on the components around the chip you're trying to get off the board. Electrolytic caps and plastic connectors, i assure you, do NOT like the 300C+ temperatures needed for unsoldering SMD's
                    • ico
                      • Dec 2014
                      • italy
                      #90
                      i found this thread because i plan to mod my saffire 56 too... and i got a lot of hints! thanks!
                      i already had opened it and bypassed mic input caps with film... but i am currently using the interface and cannot tear it apart for a while.... so it was nice to know what opamps are inside!
                      i wanted to ask if someone noted what is the frequency of the crystal oscillator... i had plans to upgrade the clock reference too...
                      if it can help others... i have found a fast but clean and effective way of removing smd opamps without a heat station.. i just use a sharp knife to cut the legs... then remoove each leg with a simple swipe with the tip of ordinary solder station...
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        #91
                        Yes, that's one way to remove SMD chips, with two caveats
                        1) That assumes, "by default", that you don't plan on re-purposing the stock opamps, and
                        2) You need to be REALLY careful not to slice through whatever traces might be running to / from / under those pins.
                        • ico
                          • Dec 2014
                          • italy
                          #92
                          yep.... not elegant and sadly this is the soldier way of desoldering sdm....
                          anyone has an idea about the frequency value of the quartz?
                          thanks!
                          • Closedbox
                            • Oct 2015
                            • Nigeria
                            #93
                            Originally posted by PhilippHoeger
                            Just finished my PSU and decoupling update and tested it a acoustically treated studio surrounding.
                            I expected to find a subtle improvement in sound, but man this is HUGE!
                            Pls can i get details on ur power supply upgrade for the focusrite pro 40
                            • 12Bass
                              • Nov 2015
                              • 29
                              Replacing ALL the opamps with 4562's will be pricey, to say the least Not to mention that i'm quite sure it'll be far beyond the "point of diminishing returns" As i've mentioned on the first page, i've quite got my mind set on (someday) replacing all the opamps with NJM2068's - cheap and really low-noise
                              Hey Khron,
                              Thanks for creating this thread. Did you ever get around to replacing the op amps on your Pro 40?
                              I have a used Pro 40 that I would like to modify by replacing/upgrading bypass capacitors as well as op amps. Some years ago I modified my Echo Gina 24 sound card and measured the results with RMAA using analog loopback testing. RMAA showed that both IMD and THD were significantly lower using the LM4562 compared with the original JRC2068 op amps. The sound was also noticeably improved, IMO - clearer, less "hazy". I've made before/after recordings and measurements on a variety of modified units, showing undeniable evidence of improvement.
                              Will have to do a bit of research on which op amps to use as some higher performance models have come out since the LM4562. At present, my Gina 24 has a pair of OP211s on the main output. However I've found that I prefer the sound of the ADA4627-1. OPA1642 provides a nice upgrade for the TL072 used in the instrument input section.
                              The Pro 40 certainly has a lot of op amps! I'd like to upgrade all of the op amps on the inputs. However, I may only upgrade the output op amps on the main (1/2) channels, and leave the rest of the outputs with the JRCs (because I am unlikely to use the rest of the output channels). Do you know which op amps are used for inputs and which are used for the outputs on the CS4272s?
                              Also, do you have any specific recommendations for a desoldering tool?
                              Thanks!
                              • Khron
                                • Sep 2006
                                • 1350
                                • Finland
                                #95
                                No, i haven't. I actually sold off the 40 this summer, to raise funds for a MOTU 896mk3 Which i promptly re-capped as well - i've got a thread documenting that too, here
                                With higher-performance opamps, you should be a bit careful, though. I don't exactly recall off the top of my head, but the opamps may or may not have small (pF-range) caps in parallel with the feedback resistors. If you use faster (greater GBW) opamps, you run the risk of potentially making some of them oscillate. Plus, some opamps are stable only for gains of 5 or more (OPA637 comes to mind).
                                That, and http://nwavguy.blogspot.fi/2011/08/o...ths-facts.html plus http://nwavguy.blogspot.fi/2011/08/o...surements.html
                                If you ask me, even "just" NJM2068's might be an improvement over the stock 4565's.
                                The safest way to determine which opamps do what would be to "beep out" the i/o pins of the codecs, and the associated opamps. Although, judging by some of the traces i can see in the photo of the mainboard, in the first post, i *think* the left-most column of 4 opamps might be the outputs. See the pairs of traces coming out of each one, and snaking their way upwards and then turning right, towards the 1/4" sockets? That would make the other 8 opamps the single-ended-to-differential converters / drivers for the ADC's.
                                If i were to replace opamps and such, i think i'd go the "proper" way, and use my (admittedly, uber-cheapo chinese) hot-air wand / station Some Al-foil-tape to shield the caps and connectors around, and a nice long but fine-tipped pair of tweezers, a bunch of flux, and that should do it
                                • 12Bass
                                  • Nov 2015
                                  • 29
                                  Hey Khron,
                                  Here's another source on op amp performance which might be of interest: http://www.sg-acoustics.ch/analogue_audio/ic_opamps/
                                  I find myself a generally skeptical and scientifically-minded person. However, there are times when I think certain people take such an approach too far, such that they are unnecessarily cynical and dismissive. Not all aspects of component performance are easily measured and some people seem eager to dismiss audible differences as pseudoscience when it may be simply that such differences have yet to be reliably quantified through measurements. I have compared the sound of a large number of op amps and have been able to reliably tell the difference between them and I'd be happy to undergo an ABX test.
                                  Further, I am of the view that if I am going to take the risk of desoldering and installing new SMD op amps that it makes sense to use the best performing replacements available. I know from previous experience that the NJM2068 would not fit that criterion. Also, I generally add local supply bypassing when installing high performance op amps and avoid those which are known to be unstable at low gain. Hopefully the Pro 40's power supply has sufficient current capacity to reliably power better performing op amps (high performance devices tend to draw more quiescent current).
                                  I'm curious if you changed the capacitors in your audio interfaces mostly for reliability reasons or if it was for sonic reasons? Did you notice any difference in the sound after the re-cap?
                                  • Khron
                                    • Sep 2006
                                    • 1350
                                    • Finland
                                    #97
                                    The recap was mostly for reliability reasons, or at the very least, for "peace of mind". And to be totally honest, i'm reasonably sure my not-that-great room swamped any potentially audible differences anyway
                                    The power supply ought to have at least SOME headroom, i'd reckon. Although, if you wanted to be extra-safe, you might want to consider sticking some heatsinks on the voltage regulators (although those nylock nuts won't be fun to undo).
                                    One other thing to consider might be to perhaps alter the voltages for the analog rails. Stock, they're +/-6.9v due to the NJM2122's which i assume do the heavy lifting, gain-wise. If you're planning to replace those too, increasing the voltages might be an option, which would lessen the voltage drop across the regulators.
                                    I can't be bothered doing all the math, but you could get close to evening out the extra dissipation due to the higher-current opamps
                                    • hmm
                                      finished one preamp using the lm4562 compared it to the stock njm2122 preamp.
                                      difference is obvious. the 4562 really shines. slightly more output and MUCH less noise. the 2122 sounds covered and thin. hard to describe but 4562 is worth its dollar
                                      The NJM2122 has at least 5 dB lower noise (1.5 nV/√Hz) than the LM4562 (2.7 nV/√Hz), though. Did you measure them under identical conditions?
                                      • Khron
                                        • Sep 2006
                                        • 1350
                                        • Finland
                                        #99
                                        I have certain doubts that any actual measuring took place
                                        • 12Bass
                                          • Nov 2015
                                          • 29
                                          A bit tangential, perhaps.... I still haven't modified my Saffire Pro 40. Am still considering replacing some of the electrolytic capacitors and possibly some of the op amps.
                                          However, I did make a number of modifications to my TC Impact Twin, including replacing electrolytic capacitors, adding polypropylene bypass caps, and replacing the original NE5532s with OPA2211As and ADA4627-1s on the 1/2 output. The modified Impact Twin's microphone preamps sound much, much, different than the Saffire Pro's stock preamps. In comparison, the modded IT sounds much clearer overall, with more depth and detail. My E935 dynamic mic sounds incredibly different in each interface; the stock Saffire Pro preamps are warmer and seemingly low-midrange focused; IMO, they sounds fairly "nice", as in not harsh, but are definitely not very transparent sounding, while the IT sounds a lot more open, which aligns with my preferences.
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
                                            no-name Radeon 9600 XT recap and cooler
                                            by momaka
                                            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                            This one was actually suggested to me by ChaosLegionnaire....
                                            11-06-2020, 07:54 PM
                                          • Foetuss
                                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                            by Foetuss
                                            Hi all
                                            Hope this is in the correct place.
                                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                            Could use some double checking to see if I'm not doing something stupid .
                                            Pictures of the boards are attached.
                                            What I will be replacing with what : (planned)
                                            Soltek Golden ::
                                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                            01-18-2025, 11:44 AM
                                          • speggio91
                                            Focusrite Scarlett Solo 3rd Gen component identification
                                            by speggio91
                                            I'm trying to repair a Focusrite Scarlett Solo 3rd Gen audio interface that was accidentally exposed to 12V on the USB-C VBUS line instead of the normal 5V. A component marked as U1 on the PCB has completely blown up together with the capacitors C17, C15.
                                            From the teardown video linked below, it's indicated that U1 is a voltage regulator (switcher) with 6 pins. Unfortunately, the original part on my board is so damaged that I can't make out any markings or identify it.
                                            Video Link: https://youtu.be/8onqBc5iTB4?si=KHtU772wsproFGZy&t=633...
                                            12-04-2024, 04:00 PM
                                          • goodpsusearch
                                            Got 4 LG L222WS 22" for free - psu recap
                                            by goodpsusearch
                                            Got 4 CCFL 16/10 monitors for free.
                                            The resolution is almost Full HD (1680x1050)
                                            VGA Input only is a bummer though.
                                            Uses cheap TN panel with terrible viewing angles.
                                            Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                                            All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                                            01-15-2022, 05:36 PM
