I'm trying to repair a Focusrite Scarlett Solo 3rd Gen audio interface that was accidentally exposed to 12V on the USB-C VBUS line instead of the normal 5V. A component marked as U1 on the PCB has completely blown up together with the capacitors C17, C15.
From the teardown video linked below, it's indicated that U1 is a voltage regulator (switcher) with 6 pins. Unfortunately, the original part on my board is so damaged that I can't make out any markings or identify it.
Video Link: https://youtu.be/8onqBc5iTB4?si=KHtU772wsproFGZy&t=633
Does anyone has a similar audio interface to analye? Also, if it's not possible to identify the exact component, are there any common 6-pin voltage regulators that could work as a replacement for this circuit?
Additional Info:
-U1 is located on the VBUS line, likely stepping down USB 5V to a lower operating voltage.
-The damage seems confined to U1, as there are no visible shorts elsewhere on the board (so far).
Thanks in advance for any help or guidance!
Additional Info:
