Focusrite Scarlett Solo 3rd Gen component identification
  • speggio91
    • Apr 2020
    • 83
    • Italy
    I'm trying to repair a Focusrite Scarlett Solo 3rd Gen audio interface that was accidentally exposed to 12V on the USB-C VBUS line instead of the normal 5V. A component marked as U1 on the PCB has completely blown up together with the capacitors C17, C15.
    From the teardown video linked below, it's indicated that U1 is a voltage regulator (switcher) with 6 pins. Unfortunately, the original part on my board is so damaged that I can't make out any markings or identify it.
    Video Link: https://youtu.be/8onqBc5iTB4?si=KHtU772wsproFGZy&t=633
    Does anyone has a similar audio interface to analye? Also, if it's not possible to identify the exact component, are there any common 6-pin voltage regulators that could work as a replacement for this circuit?
    Additional Info:
    -U1 is located on the VBUS line, likely stepping down USB 5V to a lower operating voltage.
    -The damage seems confined to U1, as there are no visible shorts elsewhere on the board (so far).
    Thanks in advance for any help or guidance!
  • speggio91
    • Apr 2020
    • 83
    • Italy
    I wanted to follow up and share the good news. I successfully repaired it! Hopefully, this post will help others who might face the same issue.
    After reaching out to Focusrite technical support, I was amazed by their pro-repair approach. They provided me with the correct U1 replacement free of charge and even shared the values of the destroyed capacitors so I could replace them properly.
    Here are the details of the replaced components:
    -U1 (VBUS voltage regulator) – Replaced with STEP DOWN CONVERTER SYNCHRONOUS 1A MP2141NGTF ADJUSTABLE "MPS"
    -C15 (Blown capacitor near U1) – 100nF, 50V, 10%, X5R, 0402 (value provided by Focusrite)
    -C17 (Blown capacitor near U1) – 10µF, 16V, 20%, X5R, 0603 (value provided by Focusrite)
    After replacing those, I discovered U4 (another voltage regulator) was overheating and also the main CPU (U2) had several pins that were shorted to ground.
    I contacted the Focusrite technical support again and they sold me a pre-programmed replacement U2 and a U4 at a fair price (17 £).
    These are the components:
    -U2 (Main CPU, XMOS processor) – Replaced with XU208 QFP64, pre-programmed
    -U4 (Step-down converter, overheating after repair) – Replaced with MP2181, 1A synchronous step-down converter
    After carefully soldering everything back and running tests, the interface is now fully functional again!
    If anyone experiences repairs with Scarlett products, I highly recommend reaching out to them first, they are incredibly helpful and willing to assist.
    Thanks again to everyone for reading this! If you have any questions about this repair, feel free to ask.
    Cheers
    • Momo_the_duck
      Schematic for Focusrite Scarlett 2i2 3rd Gen
      by Momo_the_duck
      Hello!
      New here. I just bought a broken Focusrite to begin my journey in repairing stuff.
      I would like the schematic for the Focusrite Scarlett 2i2 3rd Gen audio interface.
      Thanks in advance if anyone answers!
      09-01-2025, 10:03 AM
    • tony359
      Focusrite Scarlett 2i2 gen1 repair
      by tony359
      I have acquired a 2i2 USB sound card which came with a broken USB port. The pins were not mangled, the plastic stud was missing. I replaced it but Windows now sees something and shows a "Device Descriptor Request Failed" - which I believe it means "I see something but it's not telling me who they are"
      I found the 2i4 schematics online, I feel the digital end is identical.
      The USB goes through an USB 3343 IC which acts as interface with the host. Then it connects via ULPI protocol to the XMOS CPU, an ARM one which is connected to...
      12-18-2023, 08:20 AM
    • Shulgin
      Acer predator XB241YU Component identification
      by Shulgin
      I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
      After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
      In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
      I...
      05-11-2024, 11:06 AM
    • thebomb602
      ASUS GA402R IC identification
      by thebomb602
      Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
      also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
      EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
      11-21-2023, 02:30 PM
    • Tend0
      hp elitebook 840 G4 no 5v IC identification
      by Tend0
      Hello everythone
      i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
      i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
      05-31-2025, 09:13 PM
