Darkvoice 332 tube amp no sound
  • xaro
    • Jul 2011
    I plugged the amp in, turned it on and took a millimeter up to it and saw that im not getting anything from that resistor.
    It looks like the now white resistors were once gray but had gotten so hot it they baked (On the center cap the black film that they put over it that shows the cap rating has peeled off a little and you can see the metal casing.)
    Info i found about the resistors
    RX21-10W
    Would this resistor be a suitable replacement?
    http://www.cablesandconnectors.com/PIX/nte10r.jpg
    Re: Darkvoice 332 tube amp no sound
    Not sure if they are bleeding resistors or part of the Phi filter, are the resistors connected with one leg to the positive leg of the Black DC filter cap and another leg is connected to the Negative leg of the cap. Do you know if it is 33,000 Ohms resistor? We can calculate the wattage the resistor is dissipating if we know the voltage and the resistance value. If it is for Phi filter, then it will not be 33K, it will be a lot lower like 330 Ohm or 33 Ohms depends on the the circuits current draw and the size of the DC filter caps. Need to find the service manual for it. It looks more like dual phi filter setup.
    • xaro
      • Jul 2011
      The resistors are soldered onto the + ends of the caps and on the far right end there is a rod thats linked to that square box and bolted onto the frame.
      The company that makes the amp is based in china and i havent had much luck finding a manual or even info on the resistors other then what i posted
      I found a pic of someone elses darkvoice 332 amp with the writing still on the resistors
        OK, they are dropping resistors setting in 2 stages Phi filter, they are 220 Ohms 10 Watts wire wound resistor.
        • xaro
          • Jul 2011
          Would those work as a replacement?
            Yes, but you should measure the Length and Diameter of the old resistor to be sure you will have enough room for the new resistors. After you replace them, I would like to find out what the voltages across each of these resistors are so I can calculate the power dissipation and see if they use under rating resistors, the Chinese may have designed using just enough to get by.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
