Philips HTS3410D Problem
  • trains58554
    • Apr 2012
    • 55
    I have a Philips HTS3410D and it has a problem that I would like to hear your thoughts as to what you may think the problem is. The problem is that the only source that works is the dvd play everything else does not put out sound.
  • trains58554
    • Apr 2012
    • 55
    Re: Philips HTS3410D Problem
    I did just noticed that when I switch sources I can hear it click in the speakers but still no sound from any source except the dvd player.
      Here are the service manuals for your stereo.
      http://elektrotanya.com/?q=showresul...oria=&kat2=all
      Power supply voltages and output voltages should be check first after the visual inspections.
      • trains58554
        • Apr 2012
        • 55
        Do you by any chance know where I can get the English version of the manual? The ones at that link are in Portuguese.
        I did check the power supply output voltage and it was putting out the right voltage. I find it very strange that the DVD player still work just every other component on it does not.
          I just download the one of many above, it is in multi language including English.
          • Pracise
            • May 2012
            I have an HTS3140D as well and the other day it shut off and the red power light is flashing. A friend suggested a fuse and another said it's toast, any have any input? Thanks!
              At least the main AC fuse is still good, otherwise you will not get flashing power light. It will require troubleshooting or real in-depth troubleshooting. Service manual should be download first. Do you have all the needed tools and some experience in electronics repair?
              • dogdad
                • Nov 2015
                • 35
                • usa
                I realize this is an old thread, but I wanted to say THANK YOU. I have 2 of the subject HTIB's on the bench right now and just found this link to the service manual, compliments of 'budm'.
                Again, THANKS!
                • janos6662000
                  Philips 47PFS7509/12 LCD TV problem
                  by janos6662000
                  Hi
                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                  I downloaded original firmware and applied the update, but the problem remained.
                  From a colleague i received a "factory package software" which is a lot bigger.
                  I made another firmware update, but still did not solve the problem.
                  Somewhere on the way the error got worse, because at the moment the...
                  08-12-2025, 12:54 PM
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
                • courtcircuit
                  Philips HTS8000 home cinema noise problem
                  by courtcircuit
                  Hello
                  I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                  Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                  Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                  I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                  Removed each of tyhe boards
                  02-08-2025, 08:22 AM
                • computeka
                  Macbook Air A2337 820-02016-07 No sound problem
                  by computeka
                  How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
                  05-08-2024, 10:26 AM
                • Alija
                  sound problem on my dell latitude 5300 2 in 1 laptop
                  by Alija
                  I have a sound problem on my dell latitude 5300 2 in 1 laptop.
                  Sound was working on the laptop and I had 2 Intel drivers and one more. When I turn on a song on You Tube, there is no sound, I uninstalled the drivers and tried to install them again, but now in the device manager the sound card is not visible, it only has Intel HD
                  Please help me
                  08-02-2022, 12:31 AM
