bad caps or something else?
  • DireMcCain
    • Jan 2012
    • 5
    I have a yamaha receiver, rx v2092, that won't turn on. Kicks in the protection circuit and shuts down immediately...unless..
    There is one board with four larger caps...two at one and and four at the other...if I heat the two caps at the front of the board with a hair dryer, the unit comes on when switched. However, if I only heat the four caps at the back of the board, the unit comes on then, too.
    But...if I jiggle either group of caps...up front or in the rear...the unit shuts
    down...
    It's a hot board...with 8 transistors mounted on a big heatsink...don't know if the caps are bad (I do not own as ESR) or if things just need to be resoldered...what you think??
    Thanks,. jim
  • midibob
    • Nov 2008
    • 285
    Re: bad caps or something else?
    Hi Jim,
    Tricky one to guess. To definitely prove whether it's a heat issue with the caps you really need some freezer spray so you can isolate them from any other components.
    Wiggling them would tend to suggest a bad joint which could be anywhere on the circuit board. Heat blasted all over could also intermittently cure it too as the board expands.
    Being as it's a reputable make, and I don't know how old it is, I probably wouldn't go for the caps as a bad joint on the board sounds more likely. Have you checked for dry joints? Quite easy to spot by eye most times.
    Good luck
    Midibob
    • Agent24
      I see dead caps
      • Oct 2007
      • 5082
      • New Zealand
      If jiggling the capacitors causes a shutdown it makes sense it could be cracked joints or some other intermittent connection issue.
      -David VanHorn
        Inspect the solder joints for small ring around the leads.
        • DireMcCain
          • Jan 2012
          • 5
          Thanks for your suggestions. The board containing the caps also contains 9 output transistors mounted on a large heat sink. Apparently jiggling the caps also caused the solder connections on some of those Qs to open. I replaced 4 and resoldered them all...
          everything works now...the Qs run hot and over time the solder fails? I guess the heat
          from the hair dryer caused something to expand just enough to make temporary contact...
          Thanks again
          • cadiman
            • Mar 2010
            • 397
            When I worked on delco radios I would put them into the freezer to make them act up and also to test them after.
            Don`t tell my wife.
            Sometimes spray is quicker and will give you a better idea where to start looking.
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
              by momaka
              03-12-2025, 03:42 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • bauto601
              KDM 480W PSU upgrade succes! (opinions?)
              by bauto601
              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
              A "nice" YoungYear unit? - Badcaps
              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
              12-26-2023, 03:05 PM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
