Sandstrom DAB Radio -
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Ok, the radio turn on but the display flickers on-off quite fast, nothing is displayed - caps look ok but may be toasted anyway.
    So what would cause the display to behave like this ? Is this perhaps a psu problem and a cap that shorts to ground ?
    When I measure voltage to the display it varies between 3.003 to 3.025 quite fast, is it possible that the voltage varies even more but that my fluke 12 don't have the brains to detect it ?
    Added a few pictures and a 10MB video showing display behavior.
    Video link to photobucket - http://s636.photobucket.com/albums/u...t=MVI_2963.mp4
  • japlytic
    • Oct 2005
    • 2086
    Re: Sandstrom DAB Radio -
    On the 5th picture, try replacing the three electrolytic capacitors in the bottom left corner, including the 1000uF 10V unit near a 3-pin through-lead IC (transistor-like package).
    If the radio works properly, replace the electrolytic capacitors on the primary side.
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      Thanks will remove them and try with some others - why would changing the primary caps help if it works after replacing the other 3 ?
      I tried to use the min/max feature on the fluke on the voltage to the display - max was 3.1.. and min was 0.017 - If thats correct I'm guessing that the caps short to ground.
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        Replaced the 3 of them no change, replaced the 2 to the left of them too no change.
        Will try so more the following days.
        Any other ideas ?
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          There's a small capacitor by the PWM/FET IC on the primary side, likely 10, 22, or 47uF - this is the start-up capacitor. Replace this capacitor (if you haven't done so already).
          If you have and the results are still the same, note down the part number on the PWM/FET IC and post it here. Also measure the voltage across that start-up capacitor. BE CAREFUL! The start-up capacitor is on the primary side, so you'll likely be measuring its voltage with respect to hot ground (this is not the same as the regular ground).
          • Gabriel
            • Jan 2010
            • 620
            • Norway
            Yes, it was the startup cap - 47uF 25V Jwco - Can't even find their homepage so I fitted fm pretty much all over.
            My fluke measured the startup cap to 47uF - guess a esr meter would be quite handy.
            Everyting works now - Thanks momaka
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              You're welcome and congrats on the fix .
              • Little Al
                • Apr 2012
                • 4
                • England
                I know this thread is over 2 years old now. But if any one is still browsing, your help much appreciated. I accidentally left the radio on for 2 weeks while on vacation. It was still working but the display brightness had gone. In a darkened room the display can be seen running. In normal lighting conditions the display is invisible. I have looked for "cooked" caps but there seems to be none. If anyone can point me in the right direction, I would be most grateful
                • Gabriel
                  • Jan 2010
                  • 620
                  • Norway
                  Welcome to the forum.
                  My caps did not look cooked at all, caps can fail without bloating.
                  The 47uF 25V Jwco was the only defect cap in my radio - I did however replace all the Jwco as they are totally crap.
                  Added a picture for you to see, try to replace the small 47uF next to the two kmg's.
                  • Little Al
                    • Apr 2012
                    • 4
                    • England
                    Hi G
                    Thanks for the picture and the info. Am sorry to appear to be an ignoramus but what are KMGs
                    Al
                    • Gabriel
                      • Jan 2010
                      • 620
                      • Norway
                      In the middle of the picture right behind the transformer you can see two caps that are brown in colour - they are marked kmg - to the left of those two you can see a small black cap.
                      That small black cap was the only caps that was defective in my radio, replace your's and see if it comes back to life.
                      • Little Al
                        • Apr 2012
                        • 4
                        • England
                        Thanks for pointing me in the right direction. Will let you know how it goes
                        • shelby5041
                          clock radio / radio lifespan?
                          by shelby5041
                          hi
                          ive got a modern digital clock radio approx 15yrs old
                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                          it uses very little power just a few watts i would imagine that may have something...
                          09-14-2024, 03:30 AM
                        • UserXP
                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                          by UserXP
                          Dear all,
                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                          My question is, do you know of this brand of capacitors and how bad are...
                          07-21-2025, 08:35 AM
                        • praveenramavath
                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                          by praveenramavath
                          Hello All,
                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                          https://www.hifivision.com/threads/m...-screen.98243/
                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                          04-26-2025, 09:08 AM
                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                          09-12-2024, 02:00 PM
                        • Omron
                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                          by Omron
                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                          - Tried to unplug radio and plug it back in into power,
                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                          05-23-2024, 01:27 PM
