Warning about certain tweeters including ribbon tweeters
  • japlytic
    • Oct 2005
    • 2086
    I have read a warning that some tweeters, especially ribbon tweeters can be damaged when a DC voltage is applied to them, such as a DC offset from an amplifier, a DC source such as a battery, or even a multimeter.
    Such tweeters require a DC blocking capacitor (which can be fitted in a crossover) to prevent damage.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Warning about certain tweeters including ribbon tweeters
    I don't think a multimeter would have enough power to cause damage. CPUs and chipsets are much more sensitive to voltage, and yet people probe motherboards checking for resistance without damaging those.
    I also found this:
    https://cdn.badcaps-static.com/pdfs/...43ee729f9b.pdf
    which suggests ribbon tweeters are even more robust and easier to fix than the normal coil types.
    • 999999999
      • Sep 2006
      • 774
      Depends on how much DC. No (typical)speaker should be subjected to much, it is an amp fault that should be corrected.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        If the crossover is passive, the tweeter will already have at least one capacitor fitted in series. So no DC hits the tweeter. If active crossovers are being used, then the amplifier must be designed with a DC servo and DC protection, so that offset is kept low at all times, even in the event of a fault.
        A working TV? How boring!
        • zesko
          xps 9520 ribbon cable
          by zesko
          I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
          There is 2 models, idk which one is needed on my laptop.
          0xkvng
          00vpr2
          Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
          Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
          thanks...
          10-23-2025, 05:03 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • Rubenlily
          Quick question about the ribbon
          by Rubenlily
          Hey,
          So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
          When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
          08-17-2023, 11:09 AM
        • dqtech
          Dell 7390 2 in 1 warning "Slow Charger"
          by dqtech
          I have try with 3 different adapter
          Dell adapter 40w - warning "Slow Charger" (charge rate 8mW)
          Dell adapter 65w - warning "Slow Charger" (charge rate 8mW)
          Power Supply Connected with BY-3200 (in bios detect 65w) - okay and no warning (charge rate 25000mW-32000mW)
          i already tried update bios and update all driver but problem still persist....any idea to solve this?...
          12-06-2023, 08:34 PM
        • Scincidae
          UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
          by Scincidae
          I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
          I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
          04-24-2022, 06:00 PM
