Nad 3240 Pe
  • TheInfamousJerry
    • Jun 2005
    • 15
    Re: Nad 3240 Pe
    Yep, saw that one too but wasn't sure because of the part "This discussion is for OUT OF CIRCUIT transistors *ONLY*."
    • TheInfamousJerry
      • Jun 2005
      • 15
      Re: Nad 3240 Pe
      Update: ONE output transistor read .002 from B to C, all others ranged from .6 to 1.7, I think I'll remove it and test it individually, thanks again guys for ALL the replies.
      • TheInfamousJerry
        • Jun 2005
        • 15
        Re: Nad 3240 Pe
        Damn wont let me edit, I meant one read .84 B to C(?) and 1.9 and dropping from B to E(?)
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • spleenharvester
          Reverse engineering of 18650 4-channel tester
          by spleenharvester
          Hi friends
          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
          05-04-2025, 02:43 AM
          DELL Precision 3240 Precision 3000 i9-10900 Specification for Upgrade or Repair
          This specification for the DELL Precision 3240 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3240 boardview and Precision 3240 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
          09-12-2024, 03:36 PM
          DELL Precision 3240 Precision 3000 i7-10700 Specification for Upgrade or Repair
          09-12-2024, 03:30 PM
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
