Nad 3240 Pe
  • TheInfamousJerry
    • Jun 2005
    • 15
    Nad 3240 Pe
    Well I acquired an old NAD 3240PE and it seems that one of the capacitors is blown and has leaked onto the board. It has 4 large capacitors, 2 - 80v 6800uF and 2 50v 6800uF(one of the 50v 6800 caps blew). 4 fuses were blown and I'm hesitant to replace them if they're just going to blow again. Stopped by RadiosHack and they didn't have a capacitor large enough for it. So my questions are:
    Does anyone know what each of the 4 capacitors might be for? Since one 50v is still intact do you think it'd be possible to use just one channel, or might the capacitors not be seperated by channel.
    Is there a retailer that will let me buy a few capacitors instead of in bulk?
    Is there anything I should know before trying to replace it if I find a replacement? (I've replaced caps on mobos before so I'm someone familiar with it)
    Any input would be appreciated and I'll answer any questions you have. Thanks guys.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Nad 3240 Pe
    pic please.....damn just as i was choosing a nad
    you can get caps from http://www.digikey.com/ but the amp may have other probs. wait for one of the guys here to advise.
    • TheInfamousJerry
      • Jun 2005
      • 15
      Re: Nad 3240 Pe
      Unfortunately only camera I have is a webcam and it'd be a little difficult to take a snapshot, I can try though. I checked digikey and it looked like I had to order in bulk, I could be wrong though. Also, if I came across an axial capacitor with the same rating as the radial, could I substitute that do you know?
      • TheInfamousJerry
        • Jun 2005
        • 15
        Re: Nad 3240 Pe
        Sorry for the horrible quality of the pictures.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: Nad 3240 Pe
          yes you can order from digikey not in bulk. i just dont know what to order, those specs are quite difficult. wait for kc8 to pass by and advise.
          axial is ok, it is just a different way to place the leads.
          are you trying to show those big can caps?
          • TheInfamousJerry
            • Jun 2005
            • 15
            Re: Nad 3240 Pe
            That's what I thought
            • TheInfamousJerry
              • Jun 2005
              • 15
              Re: Nad 3240 Pe
              Yep, one of them is blown (pic above)
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: Nad 3240 Pe
                ugh that is ugly. gotta be something wrong with that amp. one of the guys will assist better if you wait a bit.
                • TheInfamousJerry
                  • Jun 2005
                  • 15
                  Re: Nad 3240 Pe
                  All I got is time
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    Re: Nad 3240 Pe
                    bump...cmon guys
                    • TheInfamousJerry
                      • Jun 2005
                      • 15
                      Re: Nad 3240 Pe
                      Update:
                      Just ordered 2 capacitors from Digikey, should get here shortly. Out of curiousity, I threw some new fuses in there and turned it on. They blew immediately which isn't surprising. I'm also shocked that after researching local stores in my area for capacitors, I couldn't find a single retail store that sold them! What a world we live in.
                      • Rainbow
                        • Aug 2005
                        • 1375
                        Re: Nad 3240 Pe
                        There must be something shorted - check the transistors.
                        • TheInfamousJerry
                          • Jun 2005
                          • 15
                          Re: Nad 3240 Pe
                          Not sure how to check em really.
                          • TheInfamousJerry
                            • Jun 2005
                            • 15
                            Re: Nad 3240 Pe
                            Update:
                            I received and installed the new capacitor, plugged it in, new fuses, fuses blew again. Before it blew the speakers hummed for about a second. I did clean the board with alcohol and I'll try to research how to check/replace bad transistors as rainbow suggested.
                            • Rainbow
                              • Aug 2005
                              • 1375
                              Re: Nad 3240 Pe
                              Use diode test/beep function of a multimeter. Test NPN and PNP transistors as if they were two diodes - e.g. NPN means that base is P and both collector and emitter are N, so diode test from base to either collector or emitter should show voltage drop about 0.7V. Something is probably shorted so it will probably show very small number and beep somewhere. If there are transistors connected in parallel and they appear shorted, remove them from circuit and test one by one. It's likely that only one is bad.
                              • TheInfamousJerry
                                • Jun 2005
                                • 15
                                Re: Nad 3240 Pe
                                Do you mean the small black transistors? I'm sorry I haven't worked on audio equipment boards much. I read somewhere about possibly the output transistor but damned if I know where that is, haha. Also, I assume you mean test while unit is on and in circuit right? How would I know if it was bad when I take them out? (Sorry for all the questions, tried google and it wasn't specific enough for me)
                                • Rainbow
                                  • Aug 2005
                                  • 1375
                                  Re: Nad 3240 Pe
                                  With power off and disconnected.
                                  Power transistors should be attached to heatsink(s).
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    Re: Nad 3240 Pe
                                    nobody should mess around inside ac powered equipment when it is ON or plugged in if they do not know exactly what they are doing.
                                    • TheInfamousJerry
                                      • Jun 2005
                                      • 15
                                      Re: Nad 3240 Pe
                                      Ok thanks, will check it when I get some more time and post back.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        Re: Nad 3240 Pe
                                        http://www.anatekcorp.com/qdmmvom.htm
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                          DELL Precision 3240 Precision 3000 i9-10900 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3240 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3240 boardview and Precision 3240 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Precision 3240 Precision 3000 i7-10700 Specification for Upgrade or Repair
                                          09-12-2024, 03:30 PM
                                        • mikey5791
                                          Help on car amplifier only one channel works
                                          by mikey5791
                                          Hi all forum members,
                                          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                          08-06-2025, 10:36 PM
