Onkyo reciever, exessive ripple on +12V? how much is acceptable?
  • amelbye
    • 46
    • Norway
    I'm troubleshooting this onkyo surround reciever. It's old, but high quality. (Integra A-SV810Pro)
    The problem is bad contact in the main speaker protection relay.
    My first thought was to replace the relay. However, I measured the ripple on its' coil voltage to be about 5V, which seems quite a lot on a 12V line.
    What to you think? Is this a normal amount of ripple of this application, or should I investigate the PSU board? (the reason I'm asking is: I'll have to disassemble the whole chassis and probably even cut a few wires to get to the PSU board. This amp is not service friendly at all)
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Onkyo reciever, exessive ripple on +12V? how much is acceptable?
    FIVE volts?!?!
    In other words the voltage is oscillating between 7 and 17V?
    That doesn't sound normal at all.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I believe it would mean 5VAC on a 12VDC line.
      Ludicrous gibs!
      • Toasty
        • Jul 2007
        • 4171
        >>However, I measured the ripple on its' coil voltage to be about 5V...<<
        Measured how? With what? Meter? Scope?
        Service manual; available at: www.elektrotanya.com
        Just type in SV810 in search box.
        The 2 main supply filters are 12,000uF @ 63v. It is a split supply with +45v and -45v.
        Toast
        veritas odium parit
        • amelbye
          • 46
          • Norway
          I measured the ripple with a scope.
          I've attached a picture of the readout.
          It is not on the +50 or -50 lines though. This amp also has +12, -12 and +5, and this was measured at the positive side of the coil in the speaker protection relay (schematic page 2, part RL601).
          As a start, I had a look at the board called DC Power supply (schematic page 3), and replaced a bunch of 10uF Sanyo caps that had an ESR of about 3-6. Put in new parts measuring about 1.5. All the major capacitors seem fine, at least when I measure their ESR in-circuit.
          The result is... no sound. I must have broken something on the way. I'll post back with more information when I've made some more measurements.
          • Toasty
            • Jul 2007
            • 4171
            Output of pins 12 & 14 from Q929 µPA81C drives both RL601/2.
            http://www.alldatasheet.com/datashee...EC/UPA81C.html
            JL761 just below and to the right of the relays are C775 & 776 --> 2 - 6800uF @ 50v caps.
            I hate scanned schematics that are at a poor resolution.
            Toast
            veritas odium parit
            • Toasty
              • Jul 2007
              • 4171
              EDITED above.
              veritas odium parit
              • amelbye
                • 46
                • Norway
                Thanks for your input.
                You're right, Q929 controls the relays.
                C775 & 776 are smoothing caps for +/- 33V, which as far as I can see is only used for driving the rear power amplifier. I've measured their ESR, and they look fine
                Q929 is on the PSU board, and it seems that my fiddling with that board has either broken that chip, or at least caused it to stop opening the relays for whatever reason. And not only that. I no longer have signal on the main power transistors.
                I do however have signal at the board called "auto input balance". That's as far as I've got
                • amelbye
                  • 46
                  • Norway
                  I measured the DC voltages on Q929.
                  pin 1-6: 0V
                  pin 7: 4.4V
                  pin 8: 0V
                  The other side of the chip is unaccessible unless I take the board out, which will also mean powering off.
                  This makes sense though. DC input on pin 7 means DC output on pin 10, which will switch the relay on the power board.
                  pin1 and 16 is the rear relay
                  pin3 and 14 is the center relay
                  pin5 and 12 is the front relay
                  these pins connect to the front display panel through p007
                  p007 connects on in the upper right corner of schamatic part 4. In this schematic the front relay control line is labeled "PROTRL", center "CENRL", rear "REARL". This goes into a large chip with 80 pins.
                  http://www.alldatasheet.com/datashee...4074719FS.html
                  How do we determine why this thing has decided not to turn on the speaker relays?
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    That's a microcontroller, and if it's defective there's no easy way to replace it.
                    However you may want to check how the protection circuit works, and make sure its inputs to the microcontroller are OK.
                    • Toasty
                      • Jul 2007
                      • 4171
                      I'd like you to go back over what you've done and see what has caused the change in function or loss thereof.
                      I keep pointing at these various large uF caps because they would be supplying any other subsystems with power. You should be checking the power across them -all- for ripple. Because the ESR -looks- good, does not necessarily mean they are working correctly. They could have easily lost capacitance and are not providing the filtering necessary. This unit does not use a switching power supply, rather a linear. The ripple you are seeing is 60 cycle, and is correct for a bridge or 1/2 wave rectifier.
                      What is wrong, as you noted, is the amplitude. 99-44/100% of the time, it's a bad main filter cap or two. That must be coming from the main power supplies connected to the transformers, not any subsequent ones.
                      So, start at the main supplies and their high uF value caps, and check for ripple.
                      Once you get that cleaned up, the microprocessor and subsequent circuits may come back to life and act properly.
                      Toast
                      veritas odium parit
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        Don't know if it helps, but this might apply to this model as well.
                        http://www.youtube.com/watch?v=q_ypk0sbt5I
                        http://www.youtube.com/watch?v=mwWTSq-5IH0
                        • Jodeanss
                          Infinity sub amp and Onkyo 2 ch reciever
                          by Jodeanss
                          Hey all, looking for some advice
                          First i have an Infinity sub amp from a ps10 that turns on, makes buzzing noise louder and louder till it shuts itself off. Noticed someone on ebay fixes them so it must be quite common.
                          Anyone have any idea on what goes out on these?
                          2nd i got a 2 ch onkyo tx8050 reciever that has never had any speakers hooked up, it was used as a controller for an old bose 5.1 amp they sold way back in the day, so only thing used was the 2ch preouts fed from the optical from tv. It turns on with half dim display and then protects...
                          04-04-2023, 08:07 PM
                        • chth96
                          Is it no harm to replace with capacitor without ripple current rating?
                          by chth96
                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                          Rubycon YK DataSheet (b...
                          04-19-2024, 05:19 AM
                        • CDNBrewer
                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                          by CDNBrewer
                          Hello Everyone,
                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                          Symptoms:
                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                          • I swapped the Left and Right surround
                          Yesterday, 09:29 PM
                        • FrancescoV
                          Onkyo HT-R390 no sound output, video output ok
                          by FrancescoV
                          Good morning everyone,
                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                          The firmware reported is the following:
                          M:1.00/11107BLP
                          D:?.??/????????
                          O:1.00/11107AL
                          The DSP firmware given the question marks seems corrupt.
                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                          05-11-2025, 02:59 AM
                        • Ady2017
                          Is there a manufacturers tolerance for ripple?
                          by Ady2017
                          Hi all
                          I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
                          As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
                          The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
                          11-13-2021, 11:46 AM
