HI guys can some expert on audio please tell me if a 6.5ohm double coil woofer driver is good to replace a 8ohm woofer driver
6.5ohm woofer?
Re: 6.5ohm woofer?
http://www.ebay.com/itm/ws/eBayISAPI...ectorid=229466 -
Re: 6.5ohm woofer?
6.5 ohms is in the range of expected DCR of an 8 ohm nominal impedance driver.
I don't see any Thiele/Small params listed- you really want to do your homework and make sure a replacement driver will 'work right' with the enclosure and port, if present.
Neither is SPL (dB per watt @ 1 meter.) Sensitivity is much more important than power handling. At 95 dB/watt, only 10 watts gets the SPL to 105 dB. But with an 83 dB/watt driver needs 160 watts to reach the same level. And that's before power compression.
Also beware of 4 ohm drivers whose SPL is stated as "xx dB, 2.83V @ 1 meter." This inflates the SPL rating by 3 dB, since 2.83V RMS into 4 ohms is two watts, 3 dB more.
-Paul"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!Comment
Re: 6.5ohm woofer?
-PaulComment
Re: 6.5ohm woofer?
The resistance that you measure with the multimeter is NOT the impedance of the speaker. Typically, and 8-ohm speaker implies 8 ohms impedance, not 8 ohms resistance. An 8 ohm speaker, will usually show 4 to 6 ohms resistance, just for reference. The manufacturer's specs should tell you what you want to know. Double coil? You would have to find out how that is is designed to be driven, but I'm assuming they are in series. Some of the sub woof speakers supplement the magnet with a separate coil so find out what it is exactly before you buy.
As far as translating the speaker's ability to turn electrical power into acoustic energy, the subject easily becomes far more complex than most people will be able to handle. The speaker enclosure has much more to do with coupling speaker movement to surrounding air than the actual efficiency of the driver. In any case, a speaker designer has the tools to adjust and compensate for varying efficiency levels. As usual, it just isn't that simple.Is it plugged in?Comment
by osrexHello, this is my first post and im just a beginner, so be easy on me guy. thanks
i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
i have no datasheet at all for the LED lights, all i have is its length.
long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,... -
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by charifNeed Audio Driver for Thomson P14C4BK128 (Windows 10/11)
I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
Here are the details:- Model: Thomson P14C4BK128
- Operating System: Windows 10 64-bit
If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
Thanks in advance for your help!-
by bohabohaHello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encountered an error.
but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
any help?-
by momakaBoston Acoustics fans, this thread might not be for you.
A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual.And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
- Loading...
