Bother with sound card?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5112
    • New Zealand
    Re: Bother with sound card?
    Originally posted by toastygoodness
    SO TRUE. It's a frickin' disaster lol...
    Disaster for my disk space certainly!
    At least FLAC does have some compression though, but it's pretty sad how there is practically no support of it on any head unit.
    -David VanHorn
    • Phaihn
      • Jan 2009
      • 842
      I got a Creative Sound Blaster Audigy 2 ZS [B800] Sound Card) sound card for my computer back in 07 and am still using it today..
      I also got some cheap sound cards I am selling for $25...
      My Computer.
      AMD APU A4-3300 2.5ghz 1mb cache
      Motherboard GigaByte GA-A75M-S2V
      Kingston HyperX Blue DDR3 8GB (2x4GB)
      SB Audigy 2 ZS [B800] Sound Card
      500GB WD Caviar® Blue™
      1 Terabyte WD Caviar® Black™
      2 Terabyte WD Caviar® Black™
      • 999999999
        • Sep 2006
        • 774
        With no audio playing, turn up the volume and see if you can hear static or other noise while moving mouse around. Next, put the CPU under load like running Prime95's torture test, volume still on high, moving mouse around.
        Next, load the video card like with ATITool, it's 3D view and "scan for artifacts", again with volume up and moving mouse. Pay special attention to the moment you stop and start these tests, if the power level change when that happens causes a noise *blip*.
        These are the situations where onboard audio tends to be a problem, they have less power rail noise isolation than (most, even cheap...) sound cards.
        Overall, the Sound Blaster Live! is probably the better of the two but you may not be able to hear the difference, especially through an amp instead of driving (a load) headphones, but if you're a gamer then the SB Live! may support more /better sound effects.
        The two primary reasons not to use it would be if you need it more in a different system, or you have other PCI cards competing for the limited bandwidth available on PCI. Keep in mind you can install the card and have both it and the integral functional, switching between which is the primary to do the sound tests.
        Also there is the issue of crystal accuracy. Certain types of video capture require the audio crystal to be close to sync with another system clock, otherwise you end up with audio sync issues. If video capture is needed you might check whether it keeps sync with your preferred setup using the audio card.
        As for other audio specs of specific chipsets and codecs... it is doubtful that either the SB Live! or the integrated audio uses an especially high resolution DAC so it is doubtful the paper spec differences between them would in itself cause audible difference. So many people compare these things assuming an "all else equal" situation when even if all else were equal which is rarely the case, the other factors like power rail noise usually swamp the spec of the IC used assuming it isn't really, really bad.
        Better adapter cable is unlikely to matter assuming the one you use is average quality, coax cable construction, although use of a headphone out jack can eventually cause the weak spring contacts in it to make poor contact and a noisy or capacitive connection. A way around that while still using analog would be to mount a couple RCA jacks on a case slot backplate and wire the sound card output to those. Of course there are other equal or better audio connectors you could use but the RCA jack size, simplicity using a straight cable, and easy availability make them "good enough" while avoiding the weak headphone jack connection.
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
        • FZG
          EVGA Nu Audio Sound Card - Not Working
          by FZG
          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
          I found...
          03-07-2025, 11:44 AM
        • paparazzo79
          sound card dead after graphics card installation
          by paparazzo79
          Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
          The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
          I still can not believe that I am such a looser and don't know...
          07-23-2024, 12:22 PM
        • alpersen
          Modding, adding usb/c audio pcb to laptop with faulty sound card/chip, Lenovo L340
          by alpersen
          Hello
          After months of trying I gave up my laptops sound card. I plan to solder a sound card on pcb inside my laptops case, probably connecting to usb ports inside. Do anyone has an experience to recommend pcb type audio/sound card suitable installing inside a laptop? Probably should have some type of amplifier for connecting to internal speakers ( speakers ).
          Thank you
          11-19-2023, 09:34 AM
        • LEECH666
          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
          by LEECH666
          Good day ladies and gentleman!
          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
          01-19-2024, 05:46 PM
