Bother with sound card?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Quick question...
    I just got a nice Sony MHC-881 sound system. Connected my PC to the AUX IN port. I'm running it out of the headphones port. It's a windows XP Core 2 Duo machine. It sounds pretty darn nice, but I'm wondering if using a PCI sound card would make it sound better. The integrated one is a VIA chip.
    Or if a better headphones to aux in adapter cable would be worth it?
    Thanks.
    PS: Pandora is the most awesome thing ever xD
  • c_hegge
    • Sep 2009
    • 5219
    Re: Bother with sound card?
    I doubt it. I once had a creative X-Fi in my main PC. I didn't sound much different to the integrated realtek sound and it made flight sim X crash randomly (the program, that is, not the plane I was flying).
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      OK.
      Thanks c_hegge.
      I thought that's the answer I would get.
      • ipman
        • Jul 2011
        • 159
        You will get some better quality with high-end sound cards like M-audio, but that depends on your budget.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Well my sound card that is a Sound Blaster Live... low budget old one.
          • ipman
            • Jul 2011
            • 159
            Not much to gain then.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              The biggest difference is reducing the amount of noise you get from other components on the board. If you're not hearing static or noise when moving the mouse, etc, you should be fine. I had a mobo once that would make a faint squeal through the speakers whenever you moved the mouse. Very annoying, but fixed with a PCI sound card.
              Ludicrous gibs!
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                I will try to listen for that next time. But I have a wireless USB mouse running off the front USB ports so IDK. Thanks!
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5039
                  • New Zealand
                  If you want something pretty good go with something that uses C-Media Oxygen chipset.
                  However, if you think your current setup sounds "pretty damn nice" I wouldn't bother. Unless you're an audiophile type guy or something.
                  -David VanHorn
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    The two options here are:
                    1. VIA Integrated Audio
                    2. PCI Sound Blaster Live!
                    I'm using #1 and it sounds fine, just curious if there was a noticeable improvmement if I switched to #2? But it sounds like (pun intended) I shouldn't bother with the PCI sound card.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5039
                      • New Zealand
                      Most likely a waste of time. But then, if you never try it, you'll never know...
                      -David VanHorn
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Haha good point...maybe I will try it tomorrow :P
                        • toastygoodness
                          • Jul 2005
                          • 813
                          it won't be much better unless its some kind of balanced output or line out (usually you try to avoid any gain from the sound card to before the amp cause then noise comes in from the el-cheapo sound card). But in all honesty, if you can't hear it, don't bother, because you will end up wasting time and money.
                          believe me. i went the audio upgrade route (basically i got monitors just for music production, and that was pretty much it), started hearing differences in recordings i had, and now i can't stop buying new audio hardware (or at least wishing i had new hardware) and it forces you to buy CDs or search for FLACs.... >.> it's becoming a super expensive hobby.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5039
                            • New Zealand
                            'Once you go FLAC, you won't go back'
                            -David VanHorn
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              WTF is a FLAC? lol.
                              • toastygoodness
                                • Jul 2005
                                • 813
                                something lossless audio....
                                http://en.wikipedia.org/wiki/FLAC should work i hope.... i usually just type in wiki links like that lol....
                                • toastygoodness
                                  • Jul 2005
                                  • 813
                                  SO TRUE. It's a frickin' disaster lol...
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    If you already HAVE the card, I say go for it. If you didn't have the card, I would say don't bother.
                                    only reason I go for external audio cards is for gaming, and have 2 PCI-E F1talities die on me, I only used them for the Dolby live spdif encoding
                                    • turbozutek
                                      • Jan 2009
                                      • 71
                                      Via make some pretty nice audio chip-sets actually. I'd say a modern Via would cane an older Sound Blaster in most regards.
                                      • toastygoodness
                                        • Jul 2005
                                        • 813
                                        yeah, they really turned things around with the Envy 24. If your integrated ones aren't even on par with that, you might as well get one, since those usually run around $15, decently. It's better than the $400 i keep paying for audio interfaces lol, but that's a different story.
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
                                        • paparazzo79
                                          sound card dead after graphics card installation
                                          by paparazzo79
                                          Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                                          The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                                          I still can not believe that I am such a looser and don't know...
                                          07-23-2024, 12:22 PM
                                        • alpersen
                                          Modding, adding usb/c audio pcb to laptop with faulty sound card/chip, Lenovo L340
                                          by alpersen
                                          Hello
                                          After months of trying I gave up my laptops sound card. I plan to solder a sound card on pcb inside my laptops case, probably connecting to usb ports inside. Do anyone has an experience to recommend pcb type audio/sound card suitable installing inside a laptop? Probably should have some type of amplifier for connecting to internal speakers ( speakers ).
                                          Thank you
                                          11-19-2023, 09:34 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
