Vizio VSB 200 Sound Bar
  • bany
    • May 2011
    • 3
    I have a Vizio SV420XVt Television with a Vizio VSB 200 Sound Bar..
    The TV is connected to Directv Satellite.
    My question is: With the sound bar connected to the TV it seems the audio setting on the TV have no effect on the sound...
    I have the TV speakers OFF but when I turn them on the sound adjustments work on the TV speakers only...
    I only wish to use the sound bar without the TV speakers.
    What is the best way, if any, to connect the sound bar so I can adjust the sound qualities?
    Thanks..
    bany
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Vizio VSB 200 Sound Bar
    Are you using the analog inputs? If so, you may want to look whether your TV has sound adjustments for the headphone out. If it does, use a 3.5mm jack to RCA cable to connect the TV to the sound bar via the headphone output, and you get the adjustments as well.
    A working TV? How boring!
    • bany
      • May 2011
      • 3
      I don't have a head phone jack.
      I am using the RGB connectors now but also have a SPDIF digital cable that I can connect but I think I had it connected once before and I couldn't control the sound, like bass, treble etc...
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        With SPDIF you won't be able to control the sound anyway because it's a direct digital stream. If you don't have a headphone jack on the TV then you're outta luck, sorry.
        • bany
          • May 2011
          • 3
          Thanks..
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • ggil44
            Vizio M65-E0 No Picture, No Sound
            by ggil44
            Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
            09-03-2024, 08:30 PM
          • SeaglassPearl
            Vizio E420VA 5v drops to 3v when power cable is connected
            by SeaglassPearl
            Folks, I have a Vizio flat screen that doesn't show any signs of life (and no orange vizio glow either).
            I tested the voltages from the power board (at the connector) and I can see the 5V supply drops to 3V after the power cable is connected to the main board (5V supply reads as 5V when cable is disconnected from main board). All other rails (12V and 24V) are reading fine.
            I looked for the usual bloated caps and saw none on either board and no other tell-tall signs (black marks, burned components, etc) on either side of both boards.
            Given the 5V rail...
            12-30-2022, 05:55 PM
          • shelby5041
            vizio d40f-j09 no pic no sound standby always clear
            by shelby5041
            hi
            anybody have experience with this model tv
            07-19-2025, 06:58 AM
