Megaworks 210D Integrated Sub amplifier repair
  • amtprod
    • Apr 2014
    Re: Integrated Sub amplifier repair
    Hey all,
    I found this thread through AVS when I was searching for ways to fix my own CSW Megaworks 210D system. I had it in storage for a couple years, and when I set it up the other day it was making some really bad intermittent sounds: pops, intermittently plays music, drops out, erratic sound playback. It does it independent of touching inputs or speaker cables, and also regardless of whether the volume knob is being used or even plugged in. It never settles on one volume, and is always breaking and plays back sound broken and intermittent.
    I really have no electronic experience at all, and wondered if others had a similar issue and doing this cap replacement had fixed things? Did or does anyone know where I can get a copy of a schematic to help have this repaired?
    Thank you for your time. Really glad I came across this!! Great pics OP...very helpful!!!
      master hoarder
      • May 2008
      • 12175
      Welcome, amtprod!
      Judging by the replies/feedback in this thread, it is very likely that some new caps will fix your problem with this amp. I think it would be okay, even if you really don't have any electronic experience, as long as you can follow instructions and do your homework on reading how to do things. If you look at ljbrandt's post #16, he says he has/had no experience either and got it working.
      So re-read the thread thoroughly, and if you have any questions, ask.
      • Wilzwerx
        • Nov 2015
        • 9
        Hi all !! I know this is an old thread but am requiring some assistance I have a polycom cambridge soundworks Bash c1ply240 and have experienced the hum issue my power caps are swollen so assume they need replacing but my main issue is ...A resistor has blown at R501 and it has obliterated the markings on the body... Do you think I'm flogging a dead horse or is it worth a couple of quid and time to try and repair...its an amazing little system as I have x4 mc150 speakers as well ..... have located a cap supply but am struggling with the vaue on this known blown resistor...can anyone help?? I've posted on this thread as the megaworks 210d seems to have the exact circuit board that mine has!!
        • Wilzwerx
          • Nov 2015
          • 9
          If you look at the images ljbrandt posted the resistor i'm interested in is on image 11 at the top left corner R501 by the red coil !!
          • fzabkar
            • Mar 2009
            • 772
            That resistor and the nearby 104 (0.1uF) capacitor probably constitute a snubber. If so, then the unit should be able to function without it.
            Check the capacitor for a short circuit.
            • Wilzwerx
              • Nov 2015
              • 9
              #26
              Thanks for the speedy reply FZABKAR !! I am good at fixing things but am no way an electronics guru !! ..... So I.m back to swapping out the power caps then ? I will do this and report back ...was just worried that a crispy component was not good !! snubber = voltage spike supression circuit ? .... Well I'll order the caps off e bay and give it a go ... ... just to check i am going to order panasonic ecos2da221ba ....Thanks again !!
                • 31214
                not ebay,
                in the u.k. use farnell
                postage is free and the caps arent fakes!
                • Wilzwerx
                  • Nov 2015
                  • 9
                  #28
                  The panasonics are discontinued so i thought that one of these component clearance houses(uk address) was going to be ok ?? http://www.ebay.co.uk/itm/Panasonic-...WEBnQ#viTabs_0 but if you dont think so i will scour farnell's for a similair version.... but will take me some time probably ..... Thanks for the heads up STJ!!
                  • Wilzwerx
                    • Nov 2015
                    • 9
                    #29
                    As I'm on the "case" and in the kitchen.... thought i would test resistance on the "crispy"resistor ..... it still has a value !! (wow) thought it was u/s !! 110k from lead to lead so i guess its ok but just scarred...does this value make sense for a snubber resistor?? (apologies I am a novice at this kind of thing!!) it was originally brown with stripes so what type of resistor would i need to replace this also??
                    • Wilzwerx
                      • Nov 2015
                      • 9
                      #30
                      Does it matter if the ESR is different on a replacement capacitor? Farnell dont seem to stock an exact match other than US stock so shipping costs are high!! .....referring to e bay link on caps - that part no... on the yellow label is an RS part no and checks out through RS as the correct part ....still a goer or not ??
                      • Wilzwerx
                        • Nov 2015
                        • 9
                        #31
                        Reading through all this again ....FZABKAR..... Just to clarify did you mean test the 104 cap or the power caps for short circuit ?? I am limited in my testing capabilities and am seemingly like a dummy in my electronic fault finding !!
                        • Wilzwerx
                          • Nov 2015
                          • 9
                          #32
                          Enough of my waffle !! Sorry chaps ! I'll just get down to it and replace them caps first and report back like I said ....hopefully with good news ..but thanks for the advice/support guys ....good site ...good info....
                          • fzabkar
                            • Mar 2009
                            • 772
                            I would trace the circuit around the resistor and the 104 capacitor. Then we could see exactly what these components do.
                            • Wilzwerx
                              • Nov 2015
                              • 9
                              #34
                              the 104 capacitor and resistor R501 are part of the incoming mains supply to the power board and then subsiquent distribution to the power capacitors (that are swollen - now removed from board ready) ..Perhaps a little history.. the amp/sub are(were) connected to my pc, which regularly "goes to sleep" the unit goes to standby with no input signal ...was ok at first but then as time went on ,when the pc went to sleep the unit would go to standby with a "pop" which progressively got louder as time went on ...... then one day when I came home from work (I had forgotten to switch pc off) I had the hum problem through the speakers...So I then took it apart for an inspection!!
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • LEECH666
                                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                by LEECH666
                                Good day ladies and gentleman!
                                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                01-19-2024, 05:46 PM
                              • flibidy
                                Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                by flibidy
                                I have here a Magnum IA.100 which belongs to my parents.
                                The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                What Ive done........
                                01-01-2025, 01:26 PM
                              • jinu_j
                                How to test Subwoofer Amplifier with only a multimeter
                                by jinu_j
                                Hi Folks
                                Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                Problem
                                I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                Any advice would be appreciated...
                                08-29-2024, 02:05 AM
                              • UserXP
                                Mackie CR4 amplifier no sound
                                by UserXP
                                Hi, people.
                                I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                10-17-2020, 05:06 PM
