ROLAND DAC-15D only dry signal
  • Mabot17
    • Mar 2023
    • 47
    • ITALY
    Re: ROLAND DAC-15D only dry signal
    Hi, I made a first measurement, sinusoidal input signal of 1khz at 500mv with signal generator, tested with the oscilloscope at point 1 waveform, and I don't see anything at all, instead I should see a square waveform at 6, 5Vpp. I've posted the service manual page, I think I've set everything correctly, I think because I'm not 100% sure
    • Mabot17
      • Mar 2023
      • 47
      • ITALY
      Hi everyone, I took a step back, and before delving into the world of signals over time, I started again to measure the voltages arriving at the circuit immediately after the transformer and rectifier bridge, and I noticed a voltage at the ends of Q2 which doesn't add up to me, it should be +7v and instead it gives me more than double, instead at the ends of Q1 it is correct -7v, I measured carefully several times so I'm sure of it, it could be the capacitors or some component, or it could actually be Q2 the problem? I attach the photo of the circuit and the measurements I made, Greetings Mauro
      • budwich
        • Jul 2015
        • 3097
        Doesn't look right. Check the voltages at both the zeners going into q1 and q2.
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          q2 appears shorted or d3 is open or has bad connection . it should measure 7.6v
          • Mabot17
            • Mar 2023
            • 47
            • ITALY
            I checked the voltage at the ends of the zener diode, and indeed there was a broken solder, now the -7v and +7v voltages are correct, but the effects are still not felt. Excluding and hoping that ic7 controller is ok, I start to think that it could be a bad electrolytic capacitor, or some transistor. I'll gradually start checking the ESR of the caps etc, and then I'll move on. even with the oscilloscope, for now I don't think I can do anything else, thanks and greetings to all of you enthusiasts.
            Mauro
            • budwich
              • Jul 2015
              • 3097
              You need to follow the input waveform around giong by the points that you have posted from the service manual. You previously posted waveforms from point "2" (I think). So you need to do the same for each point as identified by the pictures in the manual. The one of interest is at point 3.
              Having said that, IF the voltage output was at 15v as you posted, it is possible that it might have taken out a few components that rely on the 7.x volts.
              • Mabot17
                • Mar 2023
                • 47
                • ITALY
                #27
                Hi everyone, it's been a while, I hope you're still with me. I finally repaired the amplifier, after various tests only the main controller remained as a suspect. I was lucky and found a working one. To make a nice work, I placed a socket and cleaned the PCB. Now everything works, I gained a lot of experience and I also had fun in the wasted time. I greet you and put a photo of the final work, good work everyone, bye. MauroClick image for larger version
                • AstutePauciloquent
                  Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                  by AstutePauciloquent
                  Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                  I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                  11-23-2023, 11:02 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • JayPoorJay
                  Converting +/- 5v to a Usable Hz Signal
                  by JayPoorJay
                  Good morning.
                  I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                  This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                  The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                  08-07-2022, 08:35 AM
                • Scruit
                  What is a normal composite signal range for a C64?
                  by Scruit
                  Hello all,
                  Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                  More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                  https://imgur.com/gallery/PpqcqPY
                  My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                  More detail:
                  Symptoms are that that I get...
                  04-28-2022, 05:33 AM
                • supravit2000
                  PS4 fat has inconsistent signal after HDMI replacement
                  by supravit2000
                  Hi, guys!
                  I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                  My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                  12-19-2022, 08:08 PM
