Samsung UN55MU6290F Panel Short, help fixing
  • EazyBone
    • Jun 2023
    • 1354
    • United states
    So the one guy said the panel short potentially could be fixed so, here's a TV. TV reboots continuously. Backlights work fine. I put some tape on the top ribbon and the TV was able to turn on and get picture. I attached a pic of which lines I taped as well as some other pics of the buffer boards. Appears the "short" is on the right side buffer board. There are no esd diodes that I see.
    Anything can be done?
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
    09-07-2024, 05:50 AM
  • unimatrix93
    SAMSUNG UN50F600 Panel short
    by unimatrix93
    Hello all, I have a presumably SAMSUNG UN50F600 (sticker is gone from the backside and it was purchased used without box, so don't know the exact model number) with black screen issue.
    I check the PSU/MB and both showing the correct voltages. Backlight working too.
    On the T-CON, I measured:
    VGL = 0.05V
    VGH = 1V
    VVD = 1.16V
    VCOM = 0.6V
    And If I disconnect the left side of the panel, I get white screen on the right side and the following values on the T-CON:
    VGL = 12.5V
    VGH = 30.5V
    VVD =...
    11-24-2022, 02:36 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
  • triplefour
    SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
    by triplefour
    TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
    tcon is built into mainboard.
    Only one cable goes to panel boards.
    there is a cable from one panel board to the other that links them.
    cost cutting measure that results in us having harder time to diagnose.
    removing the link to the second panel board allows TV to stay on with stable backlight but no image.
    used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
    07-28-2022, 07:59 PM
