UREI 1601S No output
  • kd6mtw
    • Aug 2018
    Hi there,
    Today on the bench I have a Soundcraft UREI model 1601S music mixer.
    The symptoms are:
    No sound output at the outputs. headphone and main/booth rca both have a slight hum/buzz but no sound. and sometimes intermittently I will get the sound out of the headphone jack but very weak and distorted.
    Here's what it does upon startup. The led's upon startup do their little dance and the 2nd channel "VU" leds react to a signal inputted on that channel. No reaction from channel 1. I can activate the Rec buttons and light up for second. Sometimes they act a little crazy and flash on their own, and sometimes the level leds work and other times they don't.
    As far as a visible inspection I don't see any of the obvious bulging caps, burns, signs of infestation, etc. Looks clean inside but I have a handle broken off the Phono/Line switch for channel 1 and the crossfader seems a tad loose to me. Reseated a bunch of connectors as well.
    So I read on another thread that the DAC and also some IC's are problematic with this unit. Also obtained the unobtainium schematic from here...THANK YOU @R_J ! I was about to give up after talking with customer service/tech support and, apparently Samsung is now overseeing Harmon which ate up Soundcraft. Oh great... I'll move on and save my rant about this for the tavern.
    Forgot to mention... I have pushed the reset button on the DSP board and it seems to reboot the system. Same result whether I tap it or hold it down.
    OK, so I have started with the SMPS and have these readings on the output vs. chassis ground. Read from CN2 on the smps with everything connected and music playing thru channel 2.
    PIN 1 +v2 = 9.46vdc
    PIN 2 DGND? = 0
    PIN 3 +V1 = 16.46vdc
    PIN 4,5 AGND= 0
    PIN 6 -V1 = -16.97vdc
    So I would say the voltage reading are a tad high but since it they are within 10-15% I think I'll keep going but will need a little direction please as the schematic is one of those formats that I just can't wrap my head around. I've attached the schematic from R_J in the other 1601S post.
    p.s.
    I have DVM's, a 2ch Scope and signal generator at my disposal.
    Thanks,
    Eric
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • spleenharvester
    Reverse engineering of 18650 4-channel tester
    by spleenharvester
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
    05-04-2025, 02:43 AM
  • afminguela
    No signal right output master channel - TRAKTOR KONTROL S4 MK1
    by afminguela
    HI,
    i have a S4 MK1 and suddenly don't have signal at the right channel main output, both in rcd and trs outputs.
    One day I was plugging all the set ( Macbook air+ traktor kontrol) and when I play the first song, right channel was silent.
    i made all the silly checklist (SW mapping, connectors, swapping channels...etc)
    and I concluded that is a hardware issue.
    As both physical outputs are affected, I suppose it's something at the mainboard BEFORE the split. No item seems to be burned, or broken, at sightsee.
    Does...
    05-11-2023, 05:58 AM
    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
    I bought this from an eBay seller but unfortunately they only had one
    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
    I bought three of from them to also make battery packs with this output power limit in mind
    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
    04-23-2025, 05:50 AM
