GM Delco Radios and 3mm bolt
    Couldn't think of a spot for this question.. I've got quite a few GM Delco Car Stereos to disassemble. I've run into a bit of a snag. The boards are attached with tiny 3mm bolts. Had the size confirmed by a local audio shop.
    I have tried locally to find a 3mm nut driver or socket to no avail. The technician said they exist because he has one. I don't care if I have to buy it online somewhere. I need it.
    If anybody can point me in the right direction it would be a great help. Thanks!!
    www.bcrelectronics.ca
    Re: GM Delco Radios and 3mm bolt
    They come in those "Precision ..." kits in the plastic flip cases. Like the ones they call "Jewelers Screwdrivers". I have them in nut drivers, wrenches, flat and phillips screwdrivers.
    My set is in mm sizes: 3, 3.5, 4, 4.5, & 5.
    Google 3mm nut driver. Amazon, ebay, etc. have them.
      I fixed and modified delco radios in the 80s and 90s I picked up mine from snap-on. I should send you mine, I don`t use it anymore. What are you working on now? I work for cadillac ( government motors) and you can`t do a whole lot these days with out alot of factory softwhare.
