[Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
  • acedogblast
    • Feb 2023
    • 56
    Re: [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
    Disaster! The breaker for my room tripped and the "Magic Smoke" was released on the center channel. It happened when I turned the volume up. Worse yet both output driver transistors Q428 and Q434 now have shorts on collector to emitter but to base they are fine.
    • acedogblast
      • Feb 2023
      • 56
      Emitter resistors for both Q428 and Q434 measure fine at 0.5 ohms.
      • petehall347
        • Jan 2015
        • 4424
        • United Kingdom
        hope you wasn't running it with a load without output transistors .
        • lotas
          • Jan 2016
          • 4476
          • Russia
          Rather, you bought Q428 and Q434 - a fake. Now it's hard to find original transistors.
          • petehall347
            • Jan 2015
            • 4424
            • United Kingdom
            these will be original
            https://www.cricklewoodelectronics.com/2SB1647.html
            • acedogblast
              • Feb 2023
              • 56
              All of the parts I have bough are from either Digi-key or Mouser. So I don't think that they are fake. Either way I have decided to give up repairing the center channel. I now plan to disable the center channel on the amp board and use external amplification for the center channel since this AV receiver has preouts. Thanks for all of your help.
              • sima112
                Marantz pm 6005 right channel not worknig
                by sima112
                Hi guys,
                I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                01-30-2023, 12:11 PM
              • eccerr0r
                old X58 triple channel board... memtest86 memory speed?
                by eccerr0r
                Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                Yesterday, 09:06 AM
              • spleenharvester
                Reverse engineering of 18650 4-channel tester
                by spleenharvester
                Hi friends
                I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                05-04-2025, 02:43 AM
              • fytonv
                7 channel NAD receiver,Need help identifying a suitable cap replacement
                by fytonv
                My 7 channel NAD receiver has audio quality and volume issues on 2 of the channels. Sometimes they work and sometimes they don't. Sometimes they're at about half the dB level of the left channels, and then they cut out entirely. Powering off and on the receiver fixes it for a bit.
                Without much experience to really know for certain, they only apparent issue I can see is with these electrolytic capacitors on the power supply. Bulging = bad, correct? I'm looking for replacements but I'm unsure what leeway I have with the temp ratings. Are there any other specifications I need to worry...
                09-08-2022, 09:52 PM
              • erickeri1234
                Sony str-dn850 home receiver no left channel.
                by erickeri1234
                Ok start off by saying I have some tv repair but not much on the receiver end.
                Picked up a Sony str-dn850 home receiver when I first plugged it in powered it up it came on and the system check relay clicked and about 3 seconds later it went into protection mode.
                I powered it off and on. Comes on no problem.
                Hooked up speakers and it started to pop and crackle but the volume was all the way down.. and I was only getting that sound out of the left channel. Right channel had no sound.. but every time I turn the volume up it has a smell crackling sound on ever volume number......
                10-04-2021, 07:45 PM
