TCM 240020 repair
  • Roman78
    • Oct 2017
    • 54
    Re: TCM 240020 repair
    Yes, the big one is C404, has 3300uF 25V. The one between IC401, Q403 and the fuse. Or some other Cap?
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Wow ... That makes him the primary suspect .. It's just that I couldn't identify him C404 in the picture .
      • Roman78
        • Oct 2017
        • 54
        Does it? I still measure over 3300uF
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Unfortunately , yes ...
          • Roman78
            • Oct 2017
            • 54
            Ok.. so i have to order one. Don't have anything close here. Should i order one with exact the same values, so 3300uF 25V?
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              #26
              Yes , it should be the same values , and trust me , don't go for a used one from your stock since its role is important in this unit .
              • Roman78
                • Oct 2017
                • 54
                Thanks so far. I'll report....
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  #28
                  Good luck Roman ..
                  • valente222
                    help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                    by valente222
                    Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                    05-12-2025, 03:42 PM
                  • mikey5791
                    Need help to replace burned resistor in 350w atx psu
                    by mikey5791
                    Hi to all forum members,
                    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                    12-26-2024, 04:55 AM
                  • MidnightRoller
                    Can a resistor lose resistance after hot air?
                    by MidnightRoller
                    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                    02-02-2022, 11:46 PM
                  • artvandalai
                    What resistor ohm will work better to repair this waterpik?
                    by artvandalai
                    The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                    01-05-2025, 04:10 PM
                  • Astonished
                    Fixing the Charge Circuit of the Batteries of the DC Motor
                    by Astonished
                    Hi friends of electronics
                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                    Please help me fix this circuit.
                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                    01-28-2025, 06:24 AM
