Equivalent for A965 transistor
  • MirceaL
    • Dec 2022
    • 5
    Hi Guys,
    I am currently working on fixing an active subwoofer and found 2 bad transistors. One is A965 and the other one is C1815.
    C1815 is easy to find but A965 not so much , at least where I live (Romania).
    Can anyone help me identifying an alternative / equivalent for this , A965, transistor ?
    Is there an online tool / engine that I can use that could help in this ?
    Thank you
    Mircea
  • petehall347
    • Jan 2015
    • 4440
    Re: Equivalent for A965 transistor
    2sa965
    120V, 0,8A, 0,9W, 120MHz
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8331
      If you can’t find an original you have to do the pair. 2SAxxxx translates to KSAxxxx and 2SCxxxx to KSC.
      You have to look sometimes at the gain rating too, which would be an additional letter after the numbers.
      Look up a KSA916yta data sheet. That should be a match to yours. Also get the sister part KSC2316 and swap the old one out. So this should be in the driver stage of the PA.
      Cheers!
      • Med-Tech
        Transistor Equivalent
        by Med-Tech
        Hello, quick question. I am looking for an equivalent Transistor for a 9Bt. Not been able to find anything of use online, therefore I m reaching out to you all. I have found this 9bt is a MMBTRA109SS.
        Thanks for looking and assistance.
        06-09-2024, 10:05 AM
      • Nevillet
        2SB633 PNP transistor equivalent suggestions Marantz PM310
        by Nevillet
        Hi All,
        I have a 30+ year old Marantz PM310 that is blowing fuses. It appears that one of the output transistors (Q732) is shorted (Q731 is fine). It's a 2SB633 which does not seem available from the usual suppliers. Is there a more modern equivalent which would do the job?
        The complimentary NPN (Q729 & Q730) is a 2SD613.
        I have attached the service manual.
        Many thanks.
        https://www.badcaps.net/forum/attach...1&d=1629738387...
        08-23-2021, 11:22 AM
      • magneh
        Behringer Eurolive B205D repair - help identifying transistor
        by magneh
        Hello
        Got this speaker from a friend , defective. Power led comes on and off , in a loop.
        Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
        After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
        I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
        Still, I need to replace this transistor....
        06-18-2025, 02:34 AM
      • elsomer
        help to identify transistor msi ms-15ck1
        by elsomer
        hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
        02-17-2025, 05:30 PM
      • rddube
        Help with blowing transistor NAD T752 receiver
        by rddube
        I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
        Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
        I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
        09-01-2022, 05:19 AM
