Transistor Equivalent
  • Med-Tech
    • Jan 2024
    • 26
    Hello, quick question. I am looking for an equivalent Transistor for a 9Bt. Not been able to find anything of use online, therefore I m reaching out to you all. I have found this 9bt is a MMBTRA109SS.
    Thanks for looking and assistance.
    • 31214
    search local sources,
    those are usually called "digital transistors" or "pre-biased transistors"
    a common type starts with DTA
    the datasheet says the 109 is using 47k and 22k resistors
    • truclacicr
      • Apr 2019
      • 346
      • australia
      9B* = PMMT591A
      https://www.mouser.com/datasheet/2/916/PMMT591A-2938678.pdf
      https://www.amazon.ca/pcs-Transistor-PMMT591A-SOT-23-SOT-23-3/dp/B0973VVTWT
      (photo)
      • MirceaL
        Equivalent for A965 transistor
        by MirceaL
        Hi Guys,
        I am currently working on fixing an active subwoofer and found 2 bad transistors. One is A965 and the other one is C1815.
        C1815 is easy to find but A965 not so much , at least where I live (Romania).
        Can anyone help me identifying an alternative / equivalent for this , A965, transistor ?
        Is there an online tool / engine that I can use that could help in this ?
        Thank you
        Mircea
        01-13-2023, 01:29 PM
      • Nevillet
        2SB633 PNP transistor equivalent suggestions Marantz PM310
        by Nevillet
        Hi All,
        I have a 30+ year old Marantz PM310 that is blowing fuses. It appears that one of the output transistors (Q732) is shorted (Q731 is fine). It's a 2SB633 which does not seem available from the usual suppliers. Is there a more modern equivalent which would do the job?
        The complimentary NPN (Q729 & Q730) is a 2SD613.
        I have attached the service manual.
        Many thanks.
        https://www.badcaps.net/forum/attach...1&d=1629738387...
        08-23-2021, 11:22 AM
      • magneh
        Behringer Eurolive B205D repair - help identifying transistor
        by magneh
        Hello
        Got this speaker from a friend , defective. Power led comes on and off , in a loop.
        Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
        After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
        I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
        Still, I need to replace this transistor....
        06-18-2025, 02:34 AM
      • elsomer
        help to identify transistor msi ms-15ck1
        by elsomer
        hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
        02-17-2025, 05:30 PM
      • rddube
        Help with blowing transistor NAD T752 receiver
        by rddube
        I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
        Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
        I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
        09-01-2022, 05:19 AM
