2SB633 PNP transistor equivalent suggestions Marantz PM310
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I have a 30+ year old Marantz PM310 that is blowing fuses. It appears that one of the output transistors (Q732) is shorted (Q731 is fine). It's a 2SB633 which does not seem available from the usual suppliers. Is there a more modern equivalent which would do the job?
    The complimentary NPN (Q729 & Q730) is a 2SD613.
    I have attached the service manual.
    Many thanks.
    https://www.badcaps.net/forum/attach...1&d=1629738387
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: 2SB633 PNP transistor equivalent suggestions
    these ones or check out mje---- types .. https://cdn.badcaps-static.com/pdfs/...1727ebd659.pdf
    • Nevillet
      • Sep 2019
      • 272
      • United Kingdom
      Thanks Pete.
      I think I'll be safe with the B version (80V).
      I must admit I've never ordered from Mouser before.
      Are there any issues to be aware of?
      • petehall347
        • Jan 2015
        • 4440
        • United Kingdom
        only the shipping prices .. i use rs and have an account so shipping is free . they will have the motorola mje ones .
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          Can you suggest something from RS?
          • petehall347
            • Jan 2015
            • 4440
            • United Kingdom
            thinking about it the ft might be a problem with mje ones .. TIP31C TIP32C might be a better choice .
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              Thanks Pete, I have both in stock. Would you swap all 4?
              • petehall347
                • Jan 2015
                • 4440
                • United Kingdom
                i would leave the good channel as is .
                • CapLeaker
                  Leaking Member
                  • 8331
                  I replaced similar 2SBxxxx with MJE. Works fine. Change both channels. Sorry Pete…
                  • petehall347
                    • Jan 2015
                    • 4440
                    • United Kingdom
                    should not make much difference if any to the audio . outputs are just adding current .
                    • Nevillet
                      • Sep 2019
                      • 272
                      • United Kingdom
                      I have the NPN but not the PNP versions so have ordered some from my default supplier (CPC). I'll report back when it's installed. Many thanks.
                      • Med-Tech
                        Transistor Equivalent
                        by Med-Tech
                        Hello, quick question. I am looking for an equivalent Transistor for a 9Bt. Not been able to find anything of use online, therefore I m reaching out to you all. I have found this 9bt is a MMBTRA109SS.
                        Thanks for looking and assistance.
                        06-09-2024, 10:05 AM
                      • MirceaL
                        Equivalent for A965 transistor
                        by MirceaL
                        Hi Guys,
                        I am currently working on fixing an active subwoofer and found 2 bad transistors. One is A965 and the other one is C1815.
                        C1815 is easy to find but A965 not so much , at least where I live (Romania).
                        Can anyone help me identifying an alternative / equivalent for this , A965, transistor ?
                        Is there an online tool / engine that I can use that could help in this ?
                        Thank you
                        Mircea
                        01-13-2023, 01:29 PM
                      • magneh
                        Behringer Eurolive B205D repair - help identifying transistor
                        by magneh
                        Hello
                        Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                        Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                        After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                        I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                        Still, I need to replace this transistor....
                        06-18-2025, 02:34 AM
                      • nev1001
                        What zener diode might fix the sound on Maestro Mayhem gaming chair?
                        by nev1001
                        Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                        The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                        It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                        I think an issue could be a zener diode (or capacitor) which has shorted out.
                        The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                        04-17-2025, 05:09 PM
                      • elsomer
                        help to identify transistor msi ms-15ck1
                        by elsomer
                        hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                        02-17-2025, 05:30 PM
