Car amp
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Car amp
    i have on repaire a blown car amp one chanel.replace the 4 irfz34a with irfz34n and all resistors.now i give power and the new irfs get quik rapid hot in 5 sec i stop the power to save them from blown.may be the problem that is differend characteristics the new mosfets?the original part is not available. i check all components and found nothing broken.any sugestions for equivalent part?thanks for any help.
  • UNITRAX
    • Jan 2023
    • 64
    • POLAND
    Re: Car amp
    https://cdn.badcaps-static.com/pdfs/...47d84b8021.pdf
    irfz34a Id max = 30A
    irfz34e ID max = 28A
    Apart from that, the catalog notes look similar. I'd like to hear few opinions from more experienced players.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Re: Car amp
      highly doubt it the part difference would cause instant overheating, you probably have some other short in the system that you missed.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        Re: Car amp
        i suppose you did attach them to the heatsink ?
        • spiros.p
          • Dec 2020
          • 89
          • Greece
          Re: Car amp
          thanks for answers guys.all in and out components have new pads to heatsink.i order new zenner diodes.may have lackage to earth.there is no so meny components to check.the mosfets are on psu side 4 one side 4 to other side each one have 47k resistor all new replaced one 1N4754A and one yellow ring coded diode i think is 1N4148 each side.wait for parts and will see.
          • Macdonald
            Huawei Matebook dah98nmb8c0 Bios pmc file repaire
            by Macdonald
            HIE I HAVE MY HUAWEI MATEBOOK dah98nmb8c0 rev c hf
            WHEN I TRY TO SWITCH IT ON EVERYDAY IN THE MORNING IT START TO SHOW POWER AFTER 30 MINS SO I WAS SUSPECTING TO DO POWER MANAGEMENT CONTROLER ON MY BIOS BUT I AM FAILING TO GET THE (PMC) version 140.1.01.1009 any help pliz
            07-18-2023, 06:52 AM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • proxneo
            iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
            by proxneo
            Dear reader
            TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
            I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
            12-01-2023, 04:14 AM
          • lcross
            Microsoft surface go 2 1926
            by lcross
            This surface was restarted mid update, now it only boots in recovery mode, the thing is that it no longer recognizes peripherals, the usb c port doesn't work (not a hardware issue, usb port worked before this happened) already tried to insert with a usb c to usb a adapter:keyboards mouse, usb memory, and nothing works, touch is also unresponsive, surface keyboard also don't work, when booting in bios same thing and touch is unresponsive, touchscreen is good it was already tested on another device, i tried also to load a fresh copy of windows on a usbc external ssd and still it doesn't boot with...
            05-28-2025, 01:22 PM
          • jean luc ferre
            upgrading windows7 to windows10 on an old laptop toshiba satellite m40 331 allways in error
            by jean luc ferre
            on this old laptop toshiba satellite m40 331 i am trying (but failing) to upgrade frow w7 to w10 and allways i have the error : 0xc1900101 - 0c20017. The upgrading process stops with the pc blocked with the logo screen w10 on the display; then there is no activity on the disk hdd or ssd.
            it's also impossible to boot from a dvd iso bootable, the device equally blocks on the w10 logo screen...
            i verified the informations in the device manager and it seems there are no problems...
            i wonder if it's not an issue about the bios (which is very old) or an interface problem...
            05-27-2025, 07:13 AM
