i have on repaire a blown car amp one chanel.replace the 4 irfz34a with irfz34n and all resistors.now i give power and the new irfs get quik rapid hot in 5 sec i stop the power to save them from blown.may be the problem that is differend characteristics the new mosfets?the original part is not available. i check all components and found nothing broken.any sugestions for equivalent part?thanks for any help.
Car amp
Re: Car amp
https://cdn.badcaps-static.com/pdfs/...47d84b8021.pdf
irfz34a Id max = 30A
irfz34e ID max = 28A
Apart from that, the catalog notes look similar. I'd like to hear few opinions from more experienced players. -
Re: Car amp
thanks for answers guys.all in and out components have new pads to heatsink.i order new zenner diodes.may have lackage to earth.there is no so meny components to check.the mosfets are on psu side 4 one side 4 to other side each one have 47k resistor all new replaced one 1N4754A and one yellow ring coded diode i think is 1N4148 each side.wait for parts and will see.Comment
by MacdonaldHIE I HAVE MY HUAWEI MATEBOOK dah98nmb8c0 rev c hf
WHEN I TRY TO SWITCH IT ON EVERYDAY IN THE MORNING IT START TO SHOW POWER AFTER 30 MINS SO I WAS SUSPECTING TO DO POWER MANAGEMENT CONTROLER ON MY BIOS BUT I AM FAILING TO GET THE (PMC) version 140.1.01.1009 any help pliz-
Channel: BIOS Requests ONLY!
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by proxneoDear reader
TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component... -
by francisewContinuing my saga of trying to recover data from the Toshiba / KIOXIA SSD on the XPS 13 2-in-1. It is actually a single-chip NVMe storage device, including the memory and controller in a single package (not an eMMC as I wrote above). The drive appears to come in two formats. One is the single-chip direct to board version included on the Dell XPS13 7390 2-in-1. The other format is an m.2 22x30 NVMe carrier board that also includes a handful of external power regulation components.
It's unfortunate that I haven't been able to find datasheets for the Toshiba/KIOXIA BG4 series NVMe chips... -
by lcrossThis surface was restarted mid update, now it only boots in recovery mode, the thing is that it no longer recognizes peripherals, the usb c port doesn't work (not a hardware issue, usb port worked before this happened) already tried to insert with a usb c to usb a adapter:keyboards mouse, usb memory, and nothing works, touch is also unresponsive, surface keyboard also don't work, when booting in bios same thing and touch is unresponsive, touchscreen is good it was already tested on another device, i tried also to load a fresh copy of windows on a usbc external ssd and still it doesn't boot with...05-28-2025, 01:22 PM
- Loading...
