harmon/kardon sub-ts14 makes high-pitched squeal sound
  • axlmastr
    replied
    Re: harmon/kardon sub-ts14 makes high-pitched squeal sound
    This post has been up a while and I wanted to refresh it with the addition of the factory schematics. The file I'm uploading is a PDF of the operation/service manual. The service portion with the schematic, board drawings, and parts list begin on pg 15. I have read the responses that were posted. I have a used Devry School of Technology/Bell & Howell Schools Model 34 scope but don't know how to use it or any probes/leads for it. Only a VOM so some testing is not possible. I have not replaced any components yet as some suggested. Maybe the addition of this manual will help some of you pin point your solutions better and I can get his thing out of the dusty corner it is in. I'm not as familiar with the references to the "preamp stage" or "op amps". I do realize I am somewhat in over my head with this one.
  • Ermin
    replied
    @ axlmastr
    Have you solved the problem yet bro ? I have the same problem if you could help ?
    THX
  • axlmastr
    replied
    Thanks to both of you! I'll check and post my findings.
  • hardwareguy
    replied
    The preamp stage is probably oscillating. Fix the PSU and retest. If that fails, check the bypass cap on the op amps. (its a small cap, usually a ceramic across the supply pins and the ground pins) The ceramic is usually paired with an electrolytic in parallel, check this too. It probably won't be low ESR, it's a general purpose in most cases.
    Caution! The squeal you hear may have harmonics in the ultrasonic range, perhaps even into the low RF range. This isn't good for the power stage! If this is occurring, the output devices will become hot in short order.
  • mxslick
    replied
    Ok, the last post was helpful in that it stopped "working" after a rain storm. That, and the burned solder joint on the resistor leads me to believe that the 4700uf main filter caps have failed. Change them first.
    And since there are so few other caps on that main board I'd recap all of them to be sure.
    But I feel that replacing the two main filter caps will solve the problem.
  • axlmastr
    replied
    *BUMP* Any further suggestions? Others who own this sub have posted the same symptom on the web as well. I note again that one resistor in one of the pictures had gotten hot and melted (charred) a solder joint on one end. You can tell which one because of the brown heat mark on the board. This is on the pre-amp board where the input signal is converted to the output signal going to the speaker driver. I re-soldered that one resistor and confirmed continuity with no change in symptom. I did not change the resistor because its value had not changed when I removed it from the board for testing. The board where the AC coming from the wall is converted looks pristine. According to the person who owned this the subwoofer it stopped "working" after a pretty good rain storm but where it was located they didn't hear the "whistle" coming from the woofer that I heard. I took it home and plugged it up to my A/V system lowered the gain to 1/4 and turned the amps power switch on. I immediately heard a "whistle" sound like the one you would hear from a AM or HAM radio in between frequencies. The sound is steady and will change in amplitude as the volume/gain pot is increased and does not oscillate. I unhooked the inputs from my A/V system ans listened. The sound is still there with the unit powered and no input signal. Filter/phase switches have no affect. It seems like the same instance when you have a ground loop issue in a car audio system and can hear the alternator whine. Anyone have an answer or some test procedures I can try to fix this?
    Toasty has a good point about a compensation cap but I am not sure where that would be located. Pictures of both boards have been provided with a closeups of certain areas. He also mentioned a resistor "going high" from damage. I explained my findings of one particular resistor in the above text. I am not sure at what stage that component is located in the circuit to ascertain its relevance.
    stj had mentioned "a bad cap in the PSU allowing the frequency of the source/psu to pass into the amp stage". Any thoughts on this after reading what led to the symptom?
    Sorry for the lengthy and winded post but I would prefer anyone here to help me since this is such a great resource over the years. There are a lot of intelligent and skillful people supporting this great forum and I appreciate any info you can offer.
  • axlmastr
    replied
    Sorry about the delay guys. I have been knee deep in laptops to fix and this was a sideline job. I took some pics of the amplifier's input power (PSU) where some of you suggested I look. I request your comments on what you see in these pics as I note a particular area of the PCB that could be the contributor or a sign of what before it is failing. I see a large resistor with both ends rather charred but still intact. A heat marks on the PCB are notable with on solder joint looking a bit "over-cooked". The sound is present the minute the unit is powered without an input signal. It emanates from the speaker with a set tone and gains amplitude when the volume potentiometer is dialed up. It just happened one day. Hit the power off and the sound goes away with a dying whistle. Any suggestions on what to remove and replace on that board would be appreciated.
  • Toasty
    replied
    *BUMP* Any more on this axlmastr?
  • Toasty
    replied
    Another question - did this happen suddenly? one day to the next? same day?
    Or was it unused for a while and then it started?
  • Toasty
    replied
    Any volume control, or does not respond to that?
    Any changes with switch positions? filter, phase...?
    Verify voltages from PSU and scope them for noise. If you can hear it, it's under 20kHz. SMPS typically operate well above that from 30kHz-100kHz or more. Could be a harmonic, tho...
    Once they're confirmed, I'd be looking for a bad ground or compensation cap in the pre-amp/amp. Maybe a resistor in their has gone high or cracked?
    Toast
  • axlmastr
    replied
    I'll try to grab some pics. This isn't my first rodeo here. I already visually inspected the board under magnification as well as generally. No sign of the usual "visible" failures. I've done over a 800 motherboards & 130 OEM psu's in the last several years. DVD players, routers, switches/hubs, car amps, lcd monitors/televisions- they all suck these days. And it doesn't matter what the price paid is either. Thanks to the many veterans here for your help back in the early days of my re-capping this e-junk. Now I'm e-scrapping a lot of things because no one wants to pay for repairs.
    replied
    probably a bad cap in the psu allowing the frequency of the source/psu to pass into the amp stage.
  • Per Hansson
    replied
    Well we would need some pictures to see if there is anything wrong with the boards visually...
  • harmon/kardon sub-ts14 makes high-pitched squeal sound
    I have a harmon/kardon sub-ts14. When I turn the amp power on, it starts making a squealing noise though the woofer. It sounds like a single tone higher pitched frequency similar to the sound you get from a shortwave radio when the signal is weak or oscillating. This sub does not oscillate this tone- it is steady. The sub amp is unplugged from any inputs or outputs and does this when power is switched on. The system is about 3 years old and used very little. Any ideas what this may be? What puked on the board that I can fix?
  • r2digital
    Harmon Kardon AVR340 no sound on 4 channels
    by r2digital
    Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
    03-09-2024, 01:33 PM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
  • Christos Tsiligiannis
    Marian Trace Alpha sound card repair help
    by Christos Tsiligiannis
    Hello to the forum.
    My name is Christos, I am new to the forum here and i am posting from Greece.
    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
    So i tried asking for a schematic from the company and they would not give me one. Instead they...
    11-18-2024, 05:26 AM
    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:30 PM
