Cuisinart wine cooler P/S board problems
  • Jtroutt19
    • Aug 2011
    • 164
    #41
    Re: Cuisinart wine cooler P/S board problems
    Success guys! Turns out them two damn resistors was what was doing it. Cooler is working perfectly now. I did upgrade those two resistors from 1/8watt to 1/4 watt.
    Thanks for all the help guys.
      master hoarder
      • May 2008
      • 12175
      #42
      Nice work!
      Looks like you finally won the battle with those two resistors. With the caps ruled out, it just had to be something in the BJT drive circuit that was messing up the PSU. I just wasn't sure if the problem was on the primary or the secondary, so I couldn't give you any further guidance. But I'm glad you didn't give up and ended up repairing the PSU. A lot of times, that's all there is to troubleshooting - going back and forth and checking everything several times until the problem finally shows itself.
      Cheers!
      • Jtroutt19
        • Aug 2011
        • 164
        #43
        Thank you for the help! I am slowly learning all this. I have taken a few classes in AC and DC powers and basic circuit design. But theory is a lot different than the real deal. I would like to find some resources that would help me understand powersupplies a bit better.
          master hoarder
          • May 2008
          • 12175
          #44
          Though a bit dated and not 100% accurate in some small parts, this IMO is usually a good starting point for understanding basic SMPS concepts:
          http://www.hardwaresecrets.com/anato...ower-supplies/
          I've heard that YouTube also has some good videos / channels on SMPSes, though I'm not sure which. Hopefully someone else can chime in on that.
          Knowledge in the following areas would also be extremely helpful to you: resistor divider circuits, rectifier circuits, passive filters (LC/RLC), transistor circuits (switching and linear), op-amps, and finally buck-boost (for understanding APFC).
          I started by tracing out cheap half-bridge power supplies like the one in this thread and later single-transistor forward (STF) PSUs. Both are fairly simple to understand and repair. So once you understand those, the rest won't be that much harder. I still struggle with understanding some of the discrete protection circuits and compensation circuits, but that's only a small portion of SMPSes that doesn't usually go bad or cause any problems. Most of your focus should be on the large power components and their driver circuits.
          In the case of your PSU above, the two 10 Ohm resistors that were bad were part of the BJT drive circuit on the primary side - that's probably why those transistors could not switch properly and you got voltage sagging past a certain load.
          • Jtroutt19
            • Aug 2011
            • 164
            #45
            Thank you much I appreciate the input and will look at what you provided.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • KYBOSH
              Wine and Beverage Cooler Control Board Repair Attempt
              by KYBOSH
              Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
              Model number AWBC242GGFD
              Previous owner states that it needs a new motor.
              When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
              I pulled out the main control board to give a look.
              Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
              07-18-2024, 11:52 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
