Can Membrane Switches be Repaired?
  • pauldow
    • Oct 2012
    • 92
    • US
    I picked up a decent looking dishwasher from the landfill. I got it cleaned up (I think they washed sneakers in it.) and it runs fine, but the cycle selector membrane switches will only work when I squeeze an area where two segments are connected.
    From the strip of switches & LEDs, there's a glued connection to a ribbon strip going to the control module.
    Is there a way to reset that adhesive? They only sell the control panel as a complete unit for about $125/
    It's a Maytag (AKA Whirlpool) MDB8751AWB
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Can Membrane Switches be Repaired?
    Attach good pictures of the membrane switches.
      • 31047
      i'v seen people replace the rear of membranes with stripboard and push switches - you cant tell frm outside.
      although i imagine they have a nice tactile feel afterwards!
      • pauldow
        • Oct 2012
        • 92
        • US
        Thanks for the information.
        Here's some photos
        The first is what the dishwashing human operator sees
        Next is the full width of the switch strip from behind.
        And finally, the area where the switch strip, and the connector meet. When I squeeze here, it works.
          • 31047
          that'sa complex bastard, i'v never seenamembrane with led's in it before.
          not seen onewith a bonded extension cable either.
          isit really a membrane, or is the rear part fiberglass board?
          • pauldow
            • Oct 2012
            • 92
            • US
            Ah, your right. I wasn't looking at it close enough. I thought the black front plastic with the switch labels is what gives it the stiffness.
            The part with the contacts and LEDs is stiff fiberglass. is has the slot where the flexible connector is attached.
            I think I'll try some heat and pressure to see if it will make it stick better. I don't have much confidence that it will make a reliable connection though.
              • 31047
              peel the plastic off the board,
              it will probably use metal discs on the back of the buttons.
              clean them, and the pads on the board.
              if that dont work, you can get *very* low profile surface-mount push switches you may be able to solder to the board.
              they are often found in fones & stuff.
              also use a meter to check the connection between the ribbon and the pcb.
              if it's fucked i'd replace it with some ribbon cable from an old floppy/hd cable or something.
              • pauldow
                • Oct 2012
                • 92
                • US
                I got some testing done, and the switches are all OK.
                I took a small heat gun, and heated the connection area in the third photo to about 100 deg C., and then pressed it together. I also cut the slot larger where that strip goes down into the door so the joint has a bit of a shallower angle. I'm hoping that will put less strain on the glued joint than the 90 degree angle it was made with.
                It's working so far.
                Sometimes those old mechanical switches are the best. They often don't look as nice, but they were reliable.
                • edugimeno
                  Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                  by edugimeno
                  Hi There!
                  I'm trying to help my friend who owns a restaurant be just bought.
                  He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                  It's stuck using, I guess, the 2 sided tape that comes with the strip
                  The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                  09-05-2024, 09:34 AM
                • adelage
                  220v Led strip flickering
                  by adelage
                  Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                  I know that the best solution would be to get a voltage...
                  11-03-2024, 09:49 AM
                • benareeno
                  Adjustable dc power supply and tcl led strip
                  by benareeno
                  I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                  I have an adjustable dc power supply and was trying around 9 volts.
                  I have a pic of a single diode...where to put pos and neg terminals to light it up?
                  Pic of middle of strip..is this where i light the entire strip?
                  And pic of end...or does this light the entire strip?
                  Where to put pos and neg for single diode..multiple diodes and the entire...
                  07-11-2021, 02:31 PM
                • mikey5791
                  Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                  by mikey5791
                  Got this working ips led monitor by the brand of
                  Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                  Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                  09-04-2023, 03:50 AM
                • Eric Ranger
                  asus Roy strip g17 g712lv
                  by Eric Ranger
                  Hi
                  i Need help bios admin block
                  bios g712lv.314
                  post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                  07-11-2025, 08:12 PM
