Beko DIS26012 humming noise after starting up, no water
  • unimatrix93
    • Oct 2021
    • 368
    • Magyarország
    As the title says I trying to fix up this beautiful machine.
    Originally it has a blown triac on it's controlboard, which I replaced with a BTA12-800B.
    Now the machine comes up normally, I can select the program and once the program starts it won't take any water in.
    The spigot is open, it has water in it. The filter at the spigot is also free of blockage. All it does is this humming and this cracking noise. What could be the culprit?
    I took a video of the behaviour:
    VID_20251205_183300.mp4
    Thanks in advance!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8354
    The electronic water valve not opening for one reason or another… seems like the tub isn’t filling with water.
    • unimatrix93
      • Oct 2021
      • 368
      • Magyarország
      I will recheck the controlboard, maybe the triac I replaced is for the solenoid water valve. If it's true and the triac is intact, is it safe to assume that I need to replace the solenoid valve or the problem can lies elsewhere?
        • 31314
        take out the solenoid-valve assembly and inspect it.
        if it's 230v then try directly powering it to see if a plunger is stuck.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8354
          As stj said, go for the electric shut off valve first. Then check what happens from the control side. Either the valve gets power and is stuck closed, or there is no power coming from the control board.
            20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
            I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
            At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
            Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
            04-09-2023, 08:04 PM
          • tony359
            by tony359
            11-28-2023, 05:18 AM
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • Ugur87
            MacBook Air M4 A3240 Brand New Water Damage no Image
            by Ugur87
            I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
            08-28-2025, 01:09 PM
          • edugimeno
            Stagg sms12p audio amp has water damage
            by edugimeno
            Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
            I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
            There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
            There is only one signal wire connecting the first boards...
            05-24-2025, 06:00 AM
